1997 F-150 ext cab, blender motor module
Old 02-20-2007, 09:11 AM
cstein64's Avatar
cstein64
cstein64 is offline
A local AC repair place just told me that my blender motor module is bad and needs to be replaced. 7.6 hrs of labor, $600 - is this true ?
All of a sudden my A/C started blowing warm and my heat started blowing cold. It worked fine then all of a sudden it started doing that.
Any ideas..
Old 02-20-2007, 11:38 AM
Joe Finn's Avatar
Joe Finn
Joe Finn is offline
Is a blend door motor. I'm pretty sure the dash needs to come out to change it. $600 is probably in the ball park.
Old 02-20-2007, 10:22 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
Welcome to the forum cstein64
If it's the blend door motor that needs replacing it can be done without removing the dash. If it's the actual blend door then 7.6 hours is about right.
The first thing to check is the temperature control ****. They sometimes crack and then you try to adjust the temperature and the **** just spins on the control shaft.
Old 02-22-2007, 01:51 PM
trailor's Avatar
trailor
trailor is offline
any luck cstein? having the same problem right now...
rickbrad
15
08-05-2011 12:16 PM
averdin
Crossovers
07-28-2010 08:43 PM
Talltruck
08-02-2005 12:12 AM
neuera
21
05-02-2004 03:28 PM
Quick Reply: 1997 F-150 ext cab, blender motor module
