E4OD wiring diagram
E4OD wiring diagram
Can anyone help me with an E4OD wiring diagram? I have the tranny in my truck with the tranny wireing harness. I have the speed sensor input from my rear axle and I have the Throttle Position on the Injection pump. I have the Computer or the PCM and the original harness. Let me explain my dilema. I purchased a rolled 92 f-350 diesel with the E40d. I removed all the sheet metal (cab and bed) and had an 87 cab and bed from another diesel. I did keep the wiring harness from the 92 its in a box with the PCM. I should be able to use the connector for the pcm and wire in the Tranny wires about 12 of them, the Speed sensor, the TPS and 12 volts. I just dont know were to start. PLease help if you can..
Thanx in advance.
Thanx in advance.
BWD444
07-07-2017 09:53 AM
deezdrama
07-01-2016 12:38 PM
ssn2197
08-03-2011 11:11 PM
