toyota manual steering convert parts
Ok so I picked up a 83 toyota 4x4 manual steering box today along with the toyota pitman arm and draglink. I know I have to make my Fordota pitman arm for hte manual box, I also plan to make the bracket to mount it. Now I want to keep my stock colum and 3 speed colum shifter so what are the other parts I need to get. I think it's a borgsen U-joint with one end splined to make the toyota box and the other is the DD style right? And I need a bushing for inside the end of the steering colum? Wear can I get these parts from?
ok
After some careful reading and checking out the mid fifty site I think I got it
LOWER CENTERING BEARING & RETAINER . . .4625 . . . . . . . .$22.50 set
For Stock Steering Column, holds column center as well as up & down.
COUPLER, Stock Column, Gives more room, use if keeping clutch.
See drawing above for more info. . . . . . . . . .JC1116-75 . . .$29.00 ea.
That should be all I need to order right? I will be making the box mounting bracket and lower colum mount and the pitman arm. That should do it right?
460na63
02-12-2015 06:02 AM
Swe-f100
13
08-25-2013 10:16 AM
vntgtrk
05-16-2013 12:28 PM
TxF100
05-13-2009 03:09 PM
Bikewrench
16
06-03-2006 09:15 AM
