You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well after posting about adding a procharger to my 5.4 F-150 to adding a turbo to a Silverado i've finally come to the conclusion (after countless.. days.. to say the least, of internet searches, Master tect. talk time and professionals) that the best truck for me is my long dream of a Lightning. Now that i got it, the questions..
What does everyone think about substituting 1 qourt of Lucas oil for one of the 6 1/2 (or now 5 1/2) qourts of Motorcraft 5w20? (If that isn't the best oil for my truck then let me know!).. Also is the s/c tapped into the oil pan or does it have it's own supply that i need to change periodically?..can't remember
Mods are 6lb JLP pulley (boost gauge maxes out so thats what i assume is in there), JLP intake, Chip and bassani true duel X pipe modded-cat-back exhaust. If that make any difference..
Stay away from the Lucas, and pretty much any other additive.
I would run 5w30 with more than stock boost.
The blower holds its own lube.
Do you mean the gauge goes almost to the speedo, or that it gets to the 10 psi mark? Most will get to the 10 without a pulley in good air, so you might not have a pulley.
__________________
1990 F-150XLT Lariat Stillon the original engine with no squeaks or rattles at over 300k miles
4.9/M5OD/3.08
16.89@77.09
145 rwhp, 272 rwtq
2001 Lightning #127
13.18@104, no chip, no pulley, no nitrous
Confuscious say "Man who have no use for jackstand have promising career as jackstand".
Ok, good the only thing is that I just bought 5w20 so i guess i'll have to switch that out. It's way past the 10psi almost hitting the speedo, I have the stock one in hand, but which one's in the truck (lb.) I don't know.
With a stock pulley and a JLP cold air kit, my stock boost guage was pegged. Anything less than completely stock and the OEM boost guage is pretty much useless.
You can measure the lower pulley you have on your L right now, and see how many inches it is. Using the table below, you should get a pretty accurate reading as to how much more bost your s/c is producing.
Congrats! Sounds like you have a nice ride there.
Might be a good idea to get it on a dyno just to make certain it has a good tune in it.
Better safe then sorry!
__________________
( Phil )2003 SuperCrew: JLP Built Lightning block/Stage 3 heads and cams.
L-conversion/Kenne Bell upgrade blower at 16PSI/BTS,4R100 tranny/100 shot nitrous.
594HP/620TQ Without the Nitrous 1.68 60' time/11.76 @ 116.17 with the 100 shot.
Join the the Delaware Chapter, HERE
Hmmmm, 8lb lower? Usually guys won't go higher than a 6lb lower for a daily driver. Plus, overspinning the Eaton like that really doesn't do anything since it's way past operating parameters. Where did you buy the L?
Yes, fill the s/c with oil until, with the s/c level, the oil reaches the fill hole opening.
Curious, what oil did you put into the s/c?
I also agree with checking your tune on the dyno.
Stewart
__________________ The Brotherhood of FTE <-click the link 1999 F150 Lightning: WMS built block, 6lb lower, Monsterbox, Truetrac, CF driveshaft 1999 PSD F250 SC 4x4: 38R, Stage 2's, T-500, JW trans, Live Tuned, lotsa Riffraff stuff 2000 PSD Excursion 4x4: 38R, JW trans, F5, MBRP, AFE, OBA and Pre-Pump, V & B codes Never Fry Bacon NAKED!
Sweet!............If you want to have the BEST oil in your Lightning get some AMSOIL ASL 5W-30. I have been using it for awhile now and is the best oil I have ever used!
I bought just bought it from a dealer on a trade. I just re-measured it and it's exactly 9 1/4" so I assume its around a 8lb.
I used the GM supercharger oil, good thing I changed it too..it was about 2oz low and dark brown! also what does everyone think about the "boost bypass?" http://www.rpmoutlet.com/boost%20bypass.htm
I'll use a quote from the RPM website to help illustrate my information.
"The purpose of a boost bypass kit is to supply continuous boost from your supercharger when exceeding acceleration limits set by the factory. When acceleration exceeds factory limits, the boost actuator solenoid actuates the boost dump valve, relieving the superchargers pressure until the truck is shut down and restarted. "
A good example of "exceeding acceleration limits" is racing at the track. When you're in the water box, doing your burnout to heat up the tires, you can inadvertently exceed the limit, causing the boost valve dump to actuate. If that occurs and you don't turn off your engine and then restart it, when the light turns green and you stomp on the pedal, your Lightning will leave the line like a dog, worse than a n/a F150.
Now, can this condition occur on the street, in normal every day driving? I guess it can. It did to me on a rainy day, before I could react, and I redlined it faster than you can say "blown engine".
But other than the rare occasions on the street, about the only time you would need this bypass is when your racing at the 1/4 mile track, to keep it from happening when you're in the water box. So, just do what I do.
After you're finished racing for the day, just plug that back in and you're good to go.
Stewart
PS - Good call on the GM supercharger oil. Same stuff as from Ford, for about half the price.
Guess the next thing to do is install gauges and get it on the dyno. According to the Tech, (the only one at the dealer that UNDERSTOOD anything I was talking about) I should have 488/515- I'm very sketchy to say the least about that- even after he told me the L was already dyno tuned, maybe at the crank, idk . So thats probably another good reason to get it there..
What is the best combination of gauges for my situation?
