Getting a good burnout going
How do you guys with manuals get a good burnout going? Auto is easy...slam the brakes and then the gas... manuals giving me some issues, so I turn to the diesel comp guys, since we have no gas comp forum.
Stop the truck while in first and just hold the gas down?
Suggestions appreciated.
Zach, usually the way I do it is put it in second gear try to pull the truck to a stop with the brakes and lay down on the throttle. Sooner or later the rear tires are going to overcome wanting to stop, and let the burnout ensue!!! Alot of times my front tires start skidding, but it will hook sooner or later. In my gassers, I did the heel toe thing and just dropped it. That makes me nervious in this machine. It's got enough torque to really tear some shizzle up. Though I'm sure it would burn the tires just the same. Sooner or later, alcohol will end the debate of weather or not I should drop it. I'll let you know when it does.
Thanks for all the help guys. I used RubberDuck's way, as that was kinda what I was thinking beforehand, coast to a slow roll, hit the brakes, then the gas, and increase both. Tires unlock, truck comes to a quick stop, and voila...lots of smoke for my entertainment!
Thanks guys, I'm sure all methods will come in handy!
Thoroughbred Diesel
General Diesel Discussion
10-20-2016 11:23 AM
Kyre Searcher
25
07-29-2016 05:30 PM
