CALLING all MASTER TECH's
Old 02-14-2009, 10:02 AM
jsoko's Avatar
jsoko
jsoko is offline
As a Master Tech What SPARK PLUG would you put in YOUR 5.4 3V
I want your personal opinion not what FORD says
Old 02-14-2009, 10:06 AM
ggwash21's Avatar
ggwash21
ggwash21 is offline
Old 02-14-2009, 10:13 AM
jsoko's Avatar
jsoko
jsoko is offline
Originally Posted by ggwash21
NO Help I want personal opinions from those who work on & own this (ENGINE)
Old 02-14-2009, 04:44 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
personally I'd just run the OEM plugs. And just check 'em every 20-30,000 miles. really recommend you wait until the 100,000 interval, but if you are gonna do it, at least be proactive about checking them often.
Motorcraft - PZT1F (SP-462)
the one piece Champions have some issues. Some people have no problems, and some have missing problems.
Old 02-14-2009, 05:19 PM
70f100longbed's Avatar
70f100longbed
70f100longbed is offline
I would wait to change them when it's needed, not at 20k like some ppl here just because they could break, and I would put Motorcraft back in with anti-seize on the ground shield.
Old 02-14-2009, 07:12 PM
Saleenguy's Avatar
Saleenguy
Saleenguy is offline
OEM plugs, replace about every 50,000 miles +/- 5,000 miles.
Never seize them well, and torque to 170 inch pounds.
Old 02-14-2009, 10:28 PM
Ryan50hrl's Avatar
Ryan50hrl
Ryan50hrl is offline
Waiting will almost guarantee that they will break...so proactive replacement is really the best idea. I've found very few people that actually have evidence of the champion plugs missing.....i've talked to three people that said they're junk, but all three of them admited that they think champion plugs in general are junk...not these....and i for one along with a number of other people on here have them in our trucks and they're working just fine....
I'd do the champion plugs for peace of mind...
Old 02-15-2009, 03:29 PM
70f100longbed
If you follow the latest TSB they won't break. I have done several sets at 90-120k and they all came out. The longer you let the carb cleaner soak the better. Most of the plug I done soaked at least 2-3 hrs and came out with all the carbon dissolved. The motorcraft carb and tune-up cleaner in the red and white can (it's not aerosol) is the ticket. Pour 2 capfuls down each plug hole, loosen the plugs 1/8 turn, and go have a few beers or something.
Old 02-16-2009, 05:20 AM
svt2205's Avatar
svt2205
svt2205 is offline
Is the latest TSB still 08-7-6?
Old 02-16-2009, 09:36 AM
70f100longbed
Yep that's the one. The part number for the cleaner is PM-3. I think it's less than $10
krewat
Modular V10 (6.8l)
03-13-2021 04:39 PM
Jmudweiser
07-24-2011 08:42 PM
bigboi04
New Member Introductions
10-19-2006 05:09 AM
TeamMudd
1999 to 2016 Super Duty
17
09-26-2006 02:13 PM
misfitz
06-27-2005 08:36 PM
Quick Reply: CALLING all MASTER TECH's
