Error Code P0308
Found Loose Wire
I found a loose wire on the distributor end, under the air filter. I cleared the code and it has not come back. I still hear the exhaust noise, and cannot find the source, the truck is idling better.
The plugs and wires are original after 106K. Got a bit intimidated while considering replacing them, read some articles. Still not convinced that its a job worth doing, looks like a bunch of hoses, wires and stuff still needs to be removed!
Thanks for the help, the IAC, #8 plug problem and the transmission are all giving me trouble at the same time!
