Serp. belt makes a terrible noise in my new 2007, help?
Old 01-28-2007, 02:42 AM
thexman's Avatar
thexman
thexman is offline
My serpentine belt makes a terrible noise all the time now. My truck only has 2000 miles on it. (2007 6.0).
It started intermittently at around 500 miles.
I sprayed a mist of wd-40 on the belt to see if it was truely the belt and not a bearing going bad. It stopped immediately, so it is the belt. Noise comes back later of course.
I've recently tried a belt dressing. Only stops the squeal for a few miles.
This noise is so irritating, especially in a brand new truck!
Any suggestions? Think they will cover it under warranty?
Old 01-28-2007, 07:20 AM
busdriver47's Avatar
busdriver47
busdriver47 is offline
With only that many miles should be under warrenty. Unless they know that you used wd40 or belt dressing.
Old 02-14-2007, 10:48 PM
treffner's Avatar
treffner
treffner is offline
my 06 had the same problem, they replaced the belt under warranty at 9500 miles
Old 02-14-2007, 10:50 PM
Beachbumcook's Avatar
Beachbumcook
Beachbumcook is offline
Got Diesel?
Ditto....
Belt sttreched or something is out of alignment... either way it is covered.
Old 02-15-2007, 06:51 AM
EARLYTIMES's Avatar
EARLYTIMES
EARLYTIMES is offline
I had a bad belt on my new 07 F-350 too. At 1000 miles I noticed "fraying" on the belt but only in on 5" section. That told me it was the belt and not pulley problems. In my mind if one or more pulleys would have had a bad spot on them, the entire lenght of the bed would have went bad. Note: I did not have any belt noise prior to noticing the problem. Replaced under warranty.
Old 02-15-2007, 09:06 PM
jetch114's Avatar
jetch114
jetch114 is offline
mine squeaks when it is cold but once it warms up,...no more squeak??Seems wierd to me.
Old 02-15-2007, 09:18 PM
treffner's Avatar
treffner
treffner is offline
that is exactly what mine was doing, cold squeek, warm no squeek.
it took the idiots at the dealership three days to figure it out and they replaced the serpentine belt.
it hasn't happened since the belt replacement, but it was strange that it was just the belt. if it comes back I'll post about it.
Old 02-16-2007, 07:06 AM
EARLYTIMES's Avatar
EARLYTIMES
Sounds as if they had a bad batch of belts.
Old 02-16-2007, 07:57 AM
Matt75's Avatar
Matt75
Matt75 is offline
Same thing on my 07'. Built in early Dec.
Old 02-16-2007, 12:45 PM
Enomra's Avatar
Enomra
Enomra is offline
They are notorious for this cold "belt squeek" and I have not yet heard a good explanation of why....Anyone???????
Old 02-16-2007, 01:28 PM
rrrrick's Avatar
rrrrick
rrrrick is offline
they replaced the belt twice on my 06, the second time was the belt and the tensioner, then the noise went away
Old 02-17-2007, 09:30 PM
Drags's Avatar
Drags
Drags is offline
Talking
Squeak is there to let us know the truck is still Running! Ha.Ha. Mine has it too, just when cold.. Have to take it in to get it corrected.
Old 02-17-2007, 10:55 PM
emilbolboaca's Avatar
emilbolboaca
emilbolboaca is offline
my truck is doing the same cold or warm, I will change the belt
Old 02-20-2007, 09:10 PM
wb6anp's Avatar
wb6anp
wb6anp is offline
talk about coincedence, I just read this thread and this morning noticed my belt or tensioner making a squealunitl warmed up then. 7700 miles on an '06. How long does it take to change belt/tensioner?
Old 02-20-2007, 09:15 PM
treffner's Avatar
treffner
treffner is offline
it took my dealer 3 days. hopefully yours will be quicker. it should take about 2-3 hours at the most.
Quick Reply: Serp. belt makes a terrible noise in my new 2007, help?
