relocating gas tank behind seat
Old 01-27-2007, 11:22 AM
badgerbrock's Avatar
badgerbrock
badgerbrock is offline
1977
f-150
4wd
automatic transmission
dual gas tanks
i have a gas tank behind my seat and i want to move it to somewhere on the frame so i can install a sound system in my truck like my uncle done but i cant find anything to do this and on his truck he has a plastic tank strapped up to the frame but since he done this when he was in highschool he dont remember what materials he used and just wanna know if anyone has done this before,what materials they used, and how they done it
Old 01-27-2007, 01:35 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
What are the last 6 digits of your Vin#?
It makes a difference.
Old 01-27-2007, 02:07 PM
badgerbrock
i hope i got the right number....F14SR065533
Old 01-27-2007, 02:30 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Okay you have a highboy.
There are some Gas tanks available at NPD for some 4x4's.
This listing doesn't differentiate.
Aft Axle (rear) mount
F100-350 73-79 Long WB, rear mount, 19 gal., w/emiss. hole, vent pipe is towards front, repro............................................. .... F-9002-3 99.95
F100-350 73-79 Long WB, rear mount, 19 gal., w/o emiss. hole, vent pipe is towards front, repro............................................. .... F-9002-4 99.95
Old 01-27-2007, 02:34 PM
lasthighboy's Avatar
lasthighboy
lasthighboy is offline
i thought f14 meant it was a 2wd f-100 not a f-250 4x4. i thought highboys started with f26
Old 01-27-2007, 02:39 PM
lasthighboy
r u sure u got the right vin for the vehicle u described in ur first post? f14 i thought was a 2wd f-100. i didnt think 77 had a tank behind the seat. is your other tank between the rear framerails? some trucks had factory dual tanks under the box. can u find one of those and make the other tank work?
Old 01-27-2007, 03:38 PM
badgerbrock
Re:
o..boy look what i started...K first my truck is a F-150..its not a highboy..and i got the vin# right off the driverside door and it was built in december but i dont remember where i got that info but in the Blue oval truck parts catalog in 1981 F14 says f150 4x4
k i went and copied everything off the door..here it is again
the warranty # F14sr065533
wheel base 133
color RY
type/g.v.w f141
body Dr4
Trans G
axle 16j
Max/gvwr lbs 06150
model year 1977
district code 73
Old 01-27-2007, 06:02 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
81-F-150-Explorer is offline
Only the 1977 Highboys, and F-350 Chassis cabs, if I recall correctly.
One of the reasons the Highboy was dropped during mid 1977 I believe, was to get rid of the in-cab tank.
Federal Motor Vehicle Safety standards #301, was amended, and after January 1977, in cab tanks were no longer allowed.
That vin is definately for a F-150 4x4.
Weird that it has a in cab tank though, Ford stopped putting in cab tanks in half tons, as a rule, back in 1973. Real proud of their new standard tank placement too, according to some of the liturature I have.
Perhaps the truck is a highbrid, or frankentruck? No offence. or a special order?
Very interesting...
Old 01-27-2007, 06:35 PM
badgerbrock
no problem none taken...i know the truck was only owned by 2 people before i bought it..and the lady i bought it from did absolutely nothing to it.. sides let it sit and rust away..so your saying the first owner probably did this himself...no wait the cluster has the original switch for 2 tanks where would have the main tank been
o yeah by the way my truck has never left my town..it was bought at our local ford dealer and still has whats left of the dealer sticker
Old 01-27-2007, 07:51 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Duh Me. yes you are correct.
I am so used to people with F250 4x4's asking about fuel tanks
Old 01-27-2007, 09:01 PM
ranger429's Avatar
ranger429
ranger429 is offline
F10 = F-100
F14 = F-150
Old 01-27-2007, 10:51 PM
plowpusher's Avatar
plowpusher
plowpusher is offline
the in cab tank was an option in 77. I had a 77 f150 4x4 with both the in cab and rear tank factory. Badger block does your tuck have the rear tank? You coulds mount a factory style midship tank or you could find a couple aftermarket saddle tanks 77's used a fuel filler door on the side of the truck pre 77 used an indent and gas cap on the side the saddle tanks I have, have got fillers in the wheel well
Old 01-28-2007, 12:31 AM
badgerbrock
yeah i have the rear tank...side saddle tank thats what my uncle called it...but where am i going to get one of those.. and he just used the original opening on the cab and then cut down through his floor panels and into the tank...do u think the sending unit in my seat tank would just plug and play with the saddle tank
Old 01-28-2007, 10:32 AM
lasthighboy
ok mil1ion. i c that alot too. and my bad. i forgot about 77 highboys, even though i used to own one. and sorry about the vin # confusion. guess my memory is failing. i think supercabs have an X don't they? so what starts with f15? just to clear up the misinformation i started
Old 01-28-2007, 10:37 AM
ranger429's Avatar
ranger429
F15= F-150 2wd
F14= F-150 4wd
Quick Reply: relocating gas tank behind seat
