cam journals
Nope, not on these engines. Here's a pic of a 4.6L that ran out of oil for less than 90 sec while my niece pulled off of the road. (Oil pressure switch broke and pumped all of the oil into the street) It's a little blurry, but you can see the scarring and the aluminum the rolled over the oil feed hole.
What it should look like.
After no oil pressure.
Dover cylinder heads actually can repair heads like those,and has a cam bearing available for the head after the repair that can be replaced if damaged.They use a tri-metal type bearing like rod and main bearings.I know of a few performance guys that use them even if the heads are perfect-it's insurance against the heads being ruined after they've spent $2000-4000 in portwork and valvetrain if they have a failure of oil starvation issue.
JL
JL
jesse282
26
08-30-2017 10:51 PM
Jeffrey Sutton
2004 - 2008 F150
05-10-2014 05:51 AM
