59 coming soon
59 coming soon
looks like me and buddy will be getting a 59 to work on soon.
it has a 292, 4 speed. hasnt run in 12 years.
we plan on doing the indepth cleaning. drain oil, tune up, etc.
will a Fram PH8A oil filter fit the ol Y?
any tips, things i should look for in particular?
thanks
i'm new here.
thanks
i'm new here.
If you can get it to start, don't run it for long. The rear main seal is rope and will scorch because it has dried out. Running it for short periods might allow oil to re-soak the rope seal and help it from scorching.
I would use synthetic oil because it is thinner and will flow into all the parts.
Be sure to add some STP Oil treatment with ZDDP.
thanks pcmenten,
the rope seal is good to know.
i plan on replacing plugs, squirting a little oil in cylinders, drain old oil/filter. turn over by hand.
drain gas tank and check the dist. points, pllug wires etc. drain radiator and replace t-stat.
check clutch fluid and brake fluid/master.
we'll see what happens in couple weeks.
1958daisywheels
01-02-2015 01:55 PM
windsor8689
53
01-05-2011 09:04 AM
