i would but the intake and heads are alredy on and i dont want to have to buy more gaskets they look like e7s to me but there stud mount rockers and the exzaust valves look smaller maby gt40 p .any other way to id them .thanks
Is there a capital letter stamped into the head at a front corner near the valve cover surface? It sounds like you have some 60 something 289 or 302 heads, those were the only one's I know of with stud mounted rockers. The GT40/P heads have that sequence cast into the body near the exhaust ports, so they're easy to ID and I'm pretty sure they have pedistal mount rockers.
the spark plugs are 5/8 the studs are threaded in not pressed .whats rail mount
well the plugs being 5/8 well eliminate D0OE they had 13/16 plugs
the studs are screwed in so they are not factory....
Rail type not mount.....the rockers will have edges at the end of the rocker that hold it over the valve stem....
like these
yes there rail mount no guide plates one thing i did notice the valve seals are way on top and bigger not like e7 heads.and where th spark plugs plug in they have a copery colour
yes theres a nut to remove them and yes rail rockers . they look like cranes but the seals are so big and not on the bottom of the valve stems more in the middle .thanks
