1978 - 1996 Big Bronco
Good port fuel injection kit out there for 74 model year Police Interceptor 460?
Old 01-15-2007, 10:48 PM
Bear47's Avatar
Bear47
Bear47 is offline
Good port Fuel Inj kit for the 74 Police Interceptor 460 in my 78 Bronco?
Many years ago i installed a 74 PI 460 motor into a 78 Ford Bronco. It has been my daily driver ever since, having undergone every possible modification, buildup, drivetrains, motor rebuilds. While I have built the motor many times, I have always retained the same 1974 police interceptor block and heads. Since I'm retirement age (retired mechanic) and finding myself traveling more and more long distances, I need to come up with better fuel mileage since I do not ever plan to stop driving my Bronco!! I have tried the Holley ProJection 950, it worked only just ok, I didnt like the tuning capabilities, and the control box ***** kept breaking all the time. It finally caught on fire and burned the Bronco to the ground, but I have since fully restored the truck, rebuilt the 460 once again and running an AFB Carter. The carb runs will but is for **** on fuel mileage compared to any fuel injection truck. So....I am desparately looking for a great port fuel injection system that will bolt right up the my 460 BUT also has a PCM that will allow me a wide range of tables to tune via laptop control. The PCM needs to be the type that I can read/write directly to with my laptop, not have to remove the EEPROM or need a burner. I got one recommendation from a forum member: http://www.howellefi.com/shop/customer/product.php?productid=16212&cat=251&page=1 but dont know anything about the PCM friendliness. I want to be able to install this setup, then go drive and scan parameters using a wide band reference, then write a new tune and download it to the kits PCM, then repeat as necessary until I am happy with my Idle, transients, part throttle and WOT performance.
Any help please!!
Thanks in advance
Jerry Judd / Mesa, Arizona
Old 01-16-2007, 06:04 AM
desertdave35's Avatar
desertdave35
desertdave35 is offline
You need to ask this question in the motor forum. https://www.ford-trucks.com/forums/forum53/
papadelogan
18
07-16-2009 10:53 PM
socalrws
04-26-2007 06:45 PM
dino360
Engine Swaps
07-12-2005 08:31 PM
FXSTC
Arizona Chapter
08-24-2002 02:56 AM
nothingbutford
05-26-2002 06:23 PM
Quick Reply: Good port fuel injection kit out there for 74 model year Police Interceptor 460?
