1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Block Heater - Tripping My GFI
Old 01-15-2007, 12:04 PM
seville009's Avatar
seville009
seville009 is offline
As mentioned before, I had the exact same problem you experienced and the problem ended being mag chloride and road salts built up on my block heater chord connections; leading to current leakage. Once I cleaned those up, and sealed them to prevent future exposoure, my block heater is working fine in my GFI outlet -
Mark;
I haven't had a chance to check into that yet, but I don't think that it is the problem. The truck is still new (only about 1,500 miles on it) and we had such non-winter so far, it has had very little salt exposure, so I don't think that it would be a build up of that as the cause of the problem.
Thanks.
  #32
Old 01-15-2007, 01:17 PM
BPofMD's Avatar
BPofMD
BPofMD is offline
Received 1,101 Likes on 1,001 Posts
Originally Posted by TXHillCountry
I've not used my engine heater on my '03 F250 6.0L PSD, but my brother-in-law generally has to use his on his '95 F350 7.3L PSD whenever the temp drops into the 40's or below, or that 7.3 gets really hard to start. (new glow plug / relay, etc). He's got about 240K miles on it.
I've noticed that his extension cord running the heater block gets REALLY warm.
My guess like the others is that the GFI on that circuit wouldn't handle it.
rgds,
TX
Duh! Time to buy a little larger extension cord.
  #33
Old 01-16-2007, 06:26 PM
Pocket's Avatar
Pocket
Pocket is offline
I have found a solution that works for me. This goes without saying, but it's a "at your own risk" type of thing, and you need to know what you are doing when messing around with outlets in your house.
I simply went down to Home Depot and picked up a 20A GFCI outlet to replace the 15A one that keeps tripping. Swapped it out and it hasn't tripped again. So now I still have a GFCI outlet, and it's not constantly tripping. The old one was so bad that I couldn't even run any power tools in my garage off that outlet.
Anyway, that's my 2 cents.
  #34
Old 01-17-2007, 01:48 AM
lostmybeer's Avatar
lostmybeer
lostmybeer is offline
Have a nice Beer!!!
Alright, a GFI is not an overcurrent device such as a circuit breaker. It is National Electrical Code requirement for a GFI to trip if the amount of current between the Neutral (grounding electrode conductor{white wire}) and Ground (grounded conductor) exceeds 3 - 5 milliamps. The cause is most likely the block heater if the extension cord has been replaced already and power tools work just fine in the recept. Check for any type of mark on the heater cord such as a cut or scrape. Take a multimeter and test the heater plug, left blade to ground. You must have an open reading.
  #35
Old 01-21-2007, 09:37 PM
xxxpheonix's Avatar
xxxpheonix
xxxpheonix is offline
ya 20 yr electrician you are probably overloading the circuit
  #36
Old 01-21-2007, 10:06 PM
handyman43358's Avatar
handyman43358
handyman43358 is offline
This is the exact reason I tell people NOT to plug a deep freezer into a random outlet in the garage, if it's a newer home. Chances are that outlet is GFI protected and if it kicks for some random reason, you'll be throwin out some rotton mean. Pull a dedicated circuit and put in an outlet just for that.
exbxtoy
31
12-16-2016 10:09 AM
FoxxLandArc
02-25-2015 08:07 AM
FoxxLandArc
02-25-2015 02:54 AM
dscabra
41
01-29-2014 11:53 AM
GreatWhite99
01-05-2010 09:28 PM
Quick Reply: Block Heater - Tripping My GFI
