Valve ajustment on 2.9
Old 01-03-2007, 01:11 PM
unioncreek's Avatar
unioncreek
unioncreek is offline
My son has a 86 with the 2.9 that makes quite a bit of lifter noise on one cylinder. I haven't worked on the 2.9 before and need to get a manual for it. Are the lifters on the 2.9 adjustable or not?
Any help appreciated.
Bob
Old 01-04-2007, 08:28 AM
mramelbass's Avatar
mramelbass
mramelbass is offline
The lifters on a 2.9 are hydraulic, and are not adjustable. The lifters in a 2.8 can be adjusted. What brand of oil and filter is he using?
Old 01-04-2007, 01:09 PM
unioncreek's Avatar
unioncreek
I changed the oil this week end and put on a Motorcraft filter and Walmart 10-30. It sounded quite a bit quieter last night when I drove it home. The truck has 140K on it and he doesn't take very good care of it, so I took over the servicing. I was told on another webpage that they have hydraulic lifters, but that they kept the lifter adjustment that the 2.8 had on them. I'm going to pull the valve cover this weekend and make sure that it's not a bent rod and that everything is tight.
Bobg
Old 01-05-2007, 10:32 AM
mramelbass's Avatar
mramelbass
Try a better oil filter....Mobil 1. Try adding some Lucas Heavy Duty Oil Stabilizer.
Old 01-09-2007, 10:11 AM
unioncreek's Avatar
unioncreek
The valve rockers on my 2.9 are adjustable. The the rocker for the #4 exhaust valve was not adjusted right. I was able to get all the lifter noise eliminated by adjusting it.
Bobg
ledhead617
1983 - 2012 Ranger & B-Series
26
03-05-2018 12:45 AM
Blankie
Bronco II
12-23-2013 03:25 PM
pmibach
03-23-2012 09:07 AM
pmibach
03-25-2011 01:26 PM
dldagneau
Aerostar
03-06-2007 05:14 AM
Quick Reply: Valve ajustment on 2.9
