F-130?!?
F-130?!?
Hi,
My dad just picked up a beautiful '76 2wd F-150. One interesting thing however is while it says "F-150" on the body, there are eight lugs on the wheels and the GVWR indicates that its a 3/4 ton. Also, under "type" on the door jamb sticker it says "F130", and the vin is F13YRD03847 which would also seem to indicate and F-130, right?? Just curious if anyone out there can help us unravel this mystery. Thanks in advance!
The following users liked this post:
[QUOTE=velcro7279]It may not be the original body parts. Maybe someone changed the fenders from an F 150 or F 100? If it is a 76 it should have the emblems on the fenders.
Thanks for the quick response. I like the theory, but on close inspection everything seems to be very original (lts got less than 100k miles on it), and the emblems are on the fenders so I guess it passes that test. Any other ideas?
[QUOTE=LxMan1]Your VIN number: F13YRD03847
Your Model Year is August 1976.
Truck Series: Unknown, Please double check VIN number
This is what I also got when I plugged the VIN into the online decoder... But there's no question that the VIN is accurate. I'm thinking the "F13" in the beginning indicates that its not a standard model. My dad seems to think the disparity between the 1/2 ton designation and the 3/4 ton build might have something to do with heavy duty trucks being taxed differently or having different emissions standards in California (its original location).
The DSO number will tell where the truck went after it left San Jose...If the DSO is: 71...it went to LA; 72...it went to SF; 73...it went to SLC; 74...it went to Seattle, etc.
DSO Has two meanings: District Sales Office (two number code) or Domestic Special Order (a series of 4 or more numbers).
If the truck was special..the DSO will have the series of 4 or more numbers.
Edit: error corrected.
