Oil & Lubrication
lucas upper cylinder lubricant
Old 07-10-2008, 06:58 PM
comp's Avatar
comp
comp is offline
Originally Posted by vanman250
My riding lawn mower was cutting in and out, I would clean and adjust it but it would end up the same. I was going to rebuild the carburetor and I had some Lucas upper cylinder oil laying around so I put it in the gas tank. It runs great now, just as smooth as ever.
vanman250
there is cleaner in it to
  #47
Old 07-10-2008, 08:02 PM
azfordf100man's Avatar
azfordf100man
azfordf100man is offline
Lucas UCL is a good product IMO, it is more of it's name(UCL) than a cleaner though. For the best of both worlds I personally like Redline SI-1, because it is 50% PEA.
  #48
Old 07-12-2008, 08:42 PM
kermmydog's Avatar
kermmydog
kermmydog is offline
I use it in all my gas motors. Don't have any diesels. My buddy runs it in all his gas & diesel engines. Both of us like it. Sure helps lube in tank fuel pumps. That should mean longer life.
  #49
Old 07-12-2008, 09:22 PM
vanman250's Avatar
vanman250
vanman250 is offline
I put it in my 2000 F150 5.4 to clean the injectors and it seems to do a good job but my gas mileage drops 3 to 4 mpg. When I stop using it my mileage goes back up. This is just the opposite of what other tel me.
vanman250
  #50
Old 07-22-2008, 10:30 AM
comp's Avatar
comp
comp is offline
vanman250
i think i'f quit using it then
  #51
Old 08-02-2008, 11:23 PM
Rockledge's Avatar
Rockledge
Rockledge is offline
I run a couple of bottles of Lucas UCL through the fuel systems of all my Fords during the warm months of the year. I do it to "keep the pipes clean" as much as for the lubrication benefits. The gasoline sold today is pretty much devoid of any lubricants, and here in CT it's 10% ethanol (that is, alcohol) as well. Considering that Ford prices a new fuel pump for my '98 Ranger at well over $400 (yes, that's just for the part), I'm willing to make an effort to keep the original pump running smooth and strong.
  #52
Old 03-14-2011, 10:44 PM
LMLOWNER's Avatar
LMLOWNER
LMLOWNER is offline
Major lubricant test data
All the scar/data by an unbiased lab for some of the top lubricants......
Lubricity Additive Study Results - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Its quite surprising what the truth is.
  #53
Old 03-19-2011, 10:34 PM
kermmydog's Avatar
kermmydog
Very interesting. That explains why adding Lucas to my gas on my GC 5.9 Limited never helped possibly.
Craig
  #54
Old 04-12-2011, 06:20 AM
Freaksh0w's Avatar
Freaksh0w
Freaksh0w is offline
If you want just a lubricant, Lucas UCL is fine.
If you want a lubricant and a cleaner @ 70%/30% respectively, MMO is the way to go.
I was always under the impression that Lucas UCL cleaned, too, but look at the MSDS for Lucas UCL and you will see it's 100% oil. MMO is 70% oil and 30% cleaner. Now, all I use is MMO.
  #55
Old 08-28-2012, 01:34 PM
Bad Bad Leroy Brown's Avatar
Bad Bad Leroy Brown
Bad Bad Leroy Brown is offline
I'm not sure if it's been mentioned, but a tcw-3 2stroke outboard oil is one of the best UCL's you can run. It has serious lubrication and a good dose of detergents and corrosion inhibitor as well to keep things clean. You only want to run it at 2 oz per 10 gal of fuel.
  #56
Old 08-29-2012, 09:02 AM
pawpaw's Avatar
pawpaw
pawpaw is offline
Brand name & Top Tier gasolines have a UCL already blended in as part of the fuel ad pack.
  #57
Old 08-29-2012, 09:49 AM
jimandmandy's Avatar
jimandmandy
jimandmandy is offline
Ecoboost will make all of this a moot point. Direct injection takes away the ability of the fuel to clean or lubricate intake valves, since the intake ports only see air, as with a diesel.
There are already problems showing up with some GDI engines (not necessarily Ford) with intake valve deposits that can only be removed by disassembling the head. Cam overlap allows a bit of exhaust to back up in the intake port leaving deposits. VW/Audi has gone to the very complex and expensive step of having port and direct injection in combination to "wash" the intake valves with a little fuel, but not enough to detonate at extremely high compression, which is the whole point of direct injection.
  #58
Old 09-05-2012, 08:12 AM
Bad Bad Leroy Brown
Direct injection makes UCL a moot point? Upper Cylinder Lubricant may lube/clean the valves to some extent, but it is primarily a lubricant for the upper cylinder walls and upper piston ring.
I dont see the direct injection of ecoboost changing anything in that regard.
  #59
Old 01-21-2013, 03:15 AM
AndrewW's Avatar
AndrewW
AndrewW is offline
I am curious to see what the results would for a test like that on gasoline engines
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: lucas upper cylinder lubricant
