It acts like it is running out of gas, but it isn't ???
Old 12-23-2006, 10:45 PM
guss's Avatar
guss
guss is offline
my 89 does same thing,the amp gauge will even discharge when it acts up.i have replaced every senser the hole dist wirs plugs injectors temp senser and temp sender.new fuel pumps and filter and switch.i finally said heck with it and bought a 75 highboy something basic.went from 21 mpg to 5mpg but the 75 runs like a champ.
Old 12-26-2006, 12:24 PM
f22c130's Avatar
f22c130
f22c130 is offline
Well ya'll, new injectors are great, but doesn't solve the problem. Runs smoother, sounds better, but still cuts out. sorry =\
Old 12-26-2006, 01:37 PM
tim73's Avatar
tim73
tim73 is offline
Mine used to do this. I just never let it get below 1/4 tank. I drove like this for a long time. However, things got worse, including not starting...fuel pump acting a fool etc. It turned out to be my ECM, which was killed by a bad ground. I replaced it, fixed teh ground and now I no longer have any of the old problems.
Old 12-28-2006, 03:18 PM
ameritaz3038's Avatar
ameritaz3038
ameritaz3038 is offline
Originally Posted by Animalistic
Have you gone to the Ford website and entered your VIN to see if there is a recall on your truck? I am not sure on the 1996 but I remember seeing a recall on the fuel system. It has a bad habit of pumping from one tank to the other and bypassing the engine. I am not sure if this will help but I hope so, gr
where on the ford website do u enter your vin for recalls
Old 12-28-2006, 03:20 PM
f22c130's Avatar
f22c130
f22c130 is offline
Would the ECM throw a code?
Old 12-29-2006, 07:36 PM
jere925's Avatar
jere925
jere925 is offline
i own an inline 6 300 and just replaced the fuel pump relays because they were corroded. The engine was struggling just at idle, but is fine now.
fly4fun35
16
02-20-2008 10:17 AM
starwriter
01-28-2008 02:12 AM
Stroke'NPower
1999 to 2016 Super Duty
16
12-01-2007 06:27 PM
michaels
09-15-2007 07:29 PM
Quick Reply: It acts like it is running out of gas, but it isn't ???
