Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 12-17-2006, 07:31 PM
luvemhot luvemhot is offline
Garage is empty, add now
luvemhot is starting off with a positive reputation.
gunk in filter picture
Here is a pic of a filter out of a Dodge, the owner was running B-10 from stinker Gas station in Idaho.
the same gunk was in the bottom of his fuel bowl, lost his injector pump to a cost of 2 grand.
Why did it do this? I have run 4 tanks through my truck now , is there a need for worry?
Thanks, Keith
__________________
Keith
1999.5 F350 4x4 lariat, CC, LB, DP Tunner F-5, ccv , 6637 air filter, SS HPX, Hutch mod, 5 inch exhaust, 3 gauge A pillar, BTS VB
99 Mustang GT convertible
1990 f 250 almost 1 millon miles
78 jeep cj-5
  #2 (permalink)
Old 12-17-2006, 08:45 PM
willbd willbd is offline
willbd is starting off with a positive reputation.
It looks like Vaseline. What does it feel like?
__________________
95 F350 SC PSD Auto 4.10 Pro-Tech Aluminum Flatbed with side boxes AutoMeter Transmission and Boost gauges 6637 Filter mod 160K miles B&M 24K Transmission cooler Diamond Eye stainless steel exhaust 2 tank WVO
Bryan Will
  #3 (permalink)
Old 12-17-2006, 08:56 PM
feels like it to
__________________
Keith
78 jeep cj-5
  #4 (permalink)
Old 12-17-2006, 09:22 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
Does the cummapart sit a lot? Looks like it might be algae. Won't take 5 minutes for you pull your filter to see if it's from the stations tank or his.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
  #5 (permalink)
Old 12-17-2006, 09:59 PM
its not algae. but the vasline compairson is a good one. I was told by the tool binder (works for the dodge dealer)it was the lard comming back out if the fule. the bottom of the fule bowl was full of the stuff. dont have that picture yet. but will get it and how many miles he had on it
__________________
Keith
78 jeep cj-5
  #6 (permalink)
Old 12-17-2006, 11:27 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
I dont know what it is but I can tell you what it isn't. It is not "lard coming back out of the fuel".
Once the feed stock oil has been thru the transesterification process it would have repeat the process in reverse to recreate the feed stock. That would require recreating the conditions found in in the processor with all components, including glycerol, present in the right proportions.
The only way it could be lard is if the feedstock, including lard, was simply mixed with diesel and not processed.
Was your friend truly using BD or was he one of the "mix WVO and diesel together" crowd.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #7 (permalink)
Old 12-17-2006, 11:31 PM
that makes sence
__________________
Keith
78 jeep cj-5
  #8 (permalink)
Old 12-17-2006, 11:55 PM
could it be they did not refine it all the way?
__________________
Keith
78 jeep cj-5
  #9 (permalink)
Old 12-18-2006, 12:36 AM
dandelion dandelion is offline
dandelion is starting off with a positive reputation.
Bio is supposed to clean the gunk out, but wow. I have a friend who has a 96 dodge and he didnt have any problems with bio, other than the standard run a few tanks though and change the filter issue. Was the bio purchased from a station? did they use a reputable refiner? B10 is not a common mix here. we have B5, B20, B80 and B99.
  #10 (permalink)
Old 12-18-2006, 07:05 AM
Put it in a zip lock bag and place it in hot water to see if you can get it to turn into a liquid.
__________________
Bryan Will
  #11 (permalink)
Old 12-18-2006, 08:00 AM
came from stiker gas staion, the owner was one of the engineers for the bio diesel. they are reputable. they are the first gas station to sell any type of bio, was told that the b 10 was a test to see if people would by it
will see if i can get the filter and boil it.
Keith
__________________
Keith
78 jeep cj-5
  #12 (permalink)
Old 12-18-2006, 08:44 AM
Phydeaux88's Avatar
It is more likely they did a lousy job of cleaning the fuel after processing. Probably didn't wash it or allow it to settle long enough.
__________________
  #13 (permalink)
Old 12-18-2006, 10:29 AM
fabmandelux's Avatar
fabmandelux fabmandelux is offline
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Wow! In 3 years, and over 9,000 gallons I've never had anything like that [ but then I'm pretty **** about how I make my biodiesel]. I have small clear prefilters on all the rigs we use biodiesel in, and they always look very clear.
Looks like soap to me............
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #14 (permalink)
Old 12-18-2006, 12:00 PM
Phydeaux88's Avatar
If its soap I wonder what the injectors look like
__________________
  #15 (permalink)
Old 12-18-2006, 12:51 PM
it took out the pump
will have more pictures tomarow cant get them off my cell phone untill then, it dont work in the mountains.
__________________
Keith
78 jeep cj-5
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
