one wire alternators
on
I read a couple of weeks back that a 1 wire alternator is energized at a pre-set alternator RPM, whereas a multiwire Alt. is energized via one of the wires by the ignition switch. So untill you reach the specified RPM your Alt. will not be charging. The condition can be magnified if you have an overdrive transmission and/or aftermarket (under driven) pulleys. In which case the pre-set alternator RPM may not be reached as soon or ever.
This is rapidly evolving into a Ford vs. Chevy, Apple vs. PC, skis vs. snowboard kind of deal! It just isn't a very big deal either way!
on
Originally Posted by Jag Red 54
Mine must be the older style, but it only needs to get up to 1100 rpm +/-. So it really is a non-issue. Jag
Originally Posted by GreatNorthWoods
It came off an 86 Buick so it may very well be an older type. I was just surprised about it because in my previous use of 3-wire alternators I had not run into that before...but this is my first use of a combination idiot light/voltmeter too. I always ran Ammeters before.
on
It does goes to a switched hot wire. The ignition voltage is fused. That's the way the Chrysler wiring harness I used is designed...another little unanticipated surprise I encountered one day when the engine would not start because the fuse was blown!
kbarbee95
07-09-2015 03:10 PM
hick.man
05-28-2015 04:55 PM
atlanta1020
05-05-2015 07:29 PM
Tyler S
05-04-2014 10:48 PM
