3.8 Rocker Arms on a 5.0
on
I'm rebuilding a 92 3.8 V-6 in school and the rocker arms look identical to my '84 302 ones. The 3.8 V-6 have a 1.73:1 rocker arm ratio compared to the 302's 1.6:1 and the CougarNuts website says you can use 5.0 roller rockers on a 3.8 V-6. So I'm wondering if you could use the V-6 rocker arms on a 302? This would be a cheap alternative to buying expensive roller rockers. Has anyone done this before?
That's how they improved the ratio, by moving the pushrod seat closer to the fulcrum. But using them could hardly be called similar to roller rockers. Most of the gain from going from 1.6 stamped steel to 1.7 rollers is from the frictional loss in the trunion over using a fulcrum. A tad more is gained from the increased lift, and little to none from the roller tips. If the 3.8 rockers are 1.73, they're likely the same units used on the 429/460 and 351C & 351M/400. I have heard that the 3.8's heads shared a few things in common with the Cleveland heads.
Originally Posted by vman
Since there is little to no gain on the roller tip,you could use them with the roller fulcrums crane makes for the stock rocker.
bsraborn
13
06-09-2017 04:35 PM
mikeh74
12-24-2015 01:23 PM
gungho351
04-26-2005 03:28 AM
