'03 Floor Heater not working Help..it's 6* F outside
Hello,
I have an '03 F-150 Super Crew with the climate control. While I was hunting this year, the floor vents just stopped working. When I press vent it thinks for a sec, and then blows out the Defrost. Any ideas ????
Thanks for the help.
Ben
Ben
More Info
I took out the controller module (where I change the temp and fan etc) and can't see any leeks or bad connections, checked the relays with a meter and they are all getting voltage and are picking up. I couldn't get to/find the spot that the floor heater connection is.
It almost seems like there is somthing blocking the vent from changing to the floor, it seems like it is trying, but then it gives up and goes to the defrost. Hope that helps more.
Ben
Ben
Hi Ben and welcome to the forum
Like MrBSS said i think you have a vacuum leak too.
Under the hood, on the passenger's side, you'll see some vacuum hoses. Check all of them to make sure there are no broken or disconnected ones. There is also a vacuum reservoir behind the battery tray. They leak sometimes.
If you have a vacuum pump you can apply vacuum manually to the different lines, reservoir etc and see if they hold it.
passenger side firewall, you will see a small hose go thru the firewall. TEE on the eignie side. TEE goes to a canister behind the battery, an dto the manifold for vacuum. The vacuum pulls a cylinder opne and strokes the plastic door to direct air to top or bottom louvers. if it fails, it goes to defrost.
Thanks so far
I have time this afternoon to chech the above metioned hoses. Thank you for your help.
I think that I should have given more information, and that is that I am able to change from defrost to the vent, or vent and defrost, just not anything that involves the floor, so to me it would seem like it is just isolated to the floor flap (or whatever changed to this setting.)
Ben
Ben
I just replaced the heater core in my truck, and it's only blowing out of the defrost vents as well. I think it's coming from the vaccume lines that connect near the throttle pedal. They are loose as can be inside the connector right there.
Either way....that dash is NOT coming out again!!
