Was wondering if anyone else has had this problem? My 30 Amp fuse in the box under the hood, #22 keeps on popping. It doesnt pop instantly, I can put a new fuse in and start the engine and after 10- 15 min. engine stalls due to fuse popping. Just wondering if anyone else has had this same problem and found a cure? I'm going to try a hook up my code reader and see if anything comes up. THANKS!!
Yup...your fuel heater under the filter is shorted out. Their is a connector to disconnect to verify the probem. Ya can just leave it disconnected if ya want.
I unplugged mine from the outside of fuel bowl. On a 97 it was 2nd wire from top,driver side, small spade plug. If I remember correctly it was red wire with a green tracer.
Some people unplug them from inside the bowl. And other people repair/upgrade them.
I left mine unplugged, no problems.
