T98 Input shaft length
Old 05-04-2002, 10:16 PM
bhabben's Avatar
bhabben
bhabben is offline
Folks,
Do any of you have a T98 that came out from behind a 223 that you could measure the length of the input shaft for me? I have a later T18 that I might try to stick behind my 223 if it will work.
1.) What is the exact distance from the front face of the tranny to the very end of the input shaft?
2.) What is the exact length of the pilot bearing surface? This is from the tip to the start of the splines.
3.) What is the diameter of the front bearing retainer? This is the diameter that matches the index hole in the bellhousing.
4.) What are the dimensions of the bolt pattern on the front of the tranny?
Thanks for any of this info,
Brett
Old 05-05-2002, 08:14 AM
57_ford's Avatar
57_ford
57_ford is offline
thefasteddy
03-09-2021 05:42 AM
john jamieson
02-12-2017 04:37 PM
kj6opf
10-08-2016 11:12 AM
61FordBus
05-13-2010 11:09 AM
bhabben
02-27-2002 07:04 PM
Quick Reply: T98 Input shaft length
