T98 Input shaft length
Folks,
Do any of you have a T98 that came out from behind a 223 that you could measure the length of the input shaft for me? I have a later T18 that I might try to stick behind my 223 if it will work.
1.) What is the exact distance from the front face of the tranny to the very end of the input shaft?
2.) What is the exact length of the pilot bearing surface? This is from the tip to the start of the splines.
3.) What is the diameter of the front bearing retainer? This is the diameter that matches the index hole in the bellhousing.
4.) What are the dimensions of the bolt pattern on the front of the tranny?
Thanks for any of this info,
Brett
Brett
thefasteddy
03-09-2021 05:42 AM
61FordBus
05-13-2010 11:09 AM
bhabben
02-27-2002 07:04 PM
