ABS engaging for no reason?
I have a 04 Expedition (XLT). The problem that I am having is occassionally while driving all of a sudden the ABS brakes engage for no reason? I know of problems when you get them wet that they can engage, but both times it has happened it has been dry. Does anyone have any clue on this? Thanks Nate
It does have the traction asssist, however I am pretty sure that it is the ABS. Both times have been driving straight at about 35mph. All of a sudden the ABS engages. Scares the crap out of you. I put my foot on the brake and it dis-engages as it comes to a stop and then drives fine. I have to drive 700 miles home after the holidays and am scared to death. Any help would be appreciated.
Thanks,
Nate
Thanks,
Nate
Originally Posted by Leader
Until you can get it to the dealer, just pull the fuse for the ABS and disable it.
It'll drive just like an older car that never had ABS. YOU will actually have to apply the proper amount of force to the brake peddle to stop the car without locking the brakes.
Totoro
2003 Ford Expedition EB
2000 Volvo S80 T6
Search one of my threads, I think it is a combination of a bad brake sensor and differential speed sensor (on top of transmission)... very scary indeed... unplug ABS fuse until worked out.
ABS light with 'stutter/slide' while braking, can remove ABS fuse to stop premature ABS engagement (brake slide/stutter) and then replace rear differential sensor (NAPA #530780 = $11)
this may help out later too
https://www.ford-trucks.com/forums/5...ml#post3983953
Fordfamilywest
1997-2006 Expedition & Navigator
03-27-2016 09:25 AM
RxWarrior
01-03-2016 10:25 AM
