351W conversion kit
351W conversion kit
I have a 55 Ford pickup and I am installing a 351W/C6 in it. The engine came out of a 79 Ford van. I got a conversion kit from Bob's F-100 and the front crossmember hits the oil pan. I think the oil pans are different on vans than on cars and trucks. Does anyone know? thanks for any help.
351W conversion kit
Yes, they sure are. The vans and most trucks used a rear sump oil pan and all cars until the 80's used a front sump pan. In the 80's they switched to a dual sump that has two drain plugs. So I guess what I'm saying is that you have three different oil pan choices. Since you've got the rear sump pan and you've got a clearance problem, I would guess that what you need is probably a front sump pan. Anything from a car up to '79 should work fine. Make sure that you get the pickup tube to match the pan. The local parts house should be able to get you a brand new one.
