To Those who own a DP Tuner
Ok I have read and read all the comments from those of you who have purchased the DP Tuner. From what I see most everyone is VERY happy with it. Comments like ' WOW just installed runs great' are fine but what about after the initial rush of the new install? I mean I put the 5 inch exhaust on my truck and did not listen to the radio or roll the windows up for a month.
What I would like to know is this:
What do the different positions feel like? For example you switch to the 80HP ECONO. To me adding 80HP normally would NOT give you better fuel mileage. What have you noticed on that setting? <O
What about the 120 or 140 race mode. Compare to stock or compare to 80HP econo mode.<O
I always see someone say you MUST have the gauges before you install the tuner. What are you seeing as a before and after readings on the gauges? Is the Transmission temp gauge climbing? Do you end up with the Exhaust temp climbing to the bad zone? I am just looking for the after the thrill of a new mod wears off thoughts.<O
What programs do you have and what do you think of them now that they are installed.<O
What position do you drive around in normally? Do you drive in stock until the guy in the Chevy pulls up neat to you at a light?<O
Do you get a lot of smoke out of the race settings? What about the lope idle? <O
Give me your thoughts.<O
Thanks,<O
Steve<O
Thanks,<O
Steve<O
at low RPM 120 smokes quite a bit.
The better shift points and lockup are almost as nice as the added power.
When I'm lazy I drive in stock because it's quieter, but I'm quick to switch to a higher setting when 'provoked'.
If I feel 'spirited' I leave it in 60... feels good to drive and not as likely to break the tires loose.
I only rarely go to 120, but wouldn't get the chip without it. At $40 a tune it's the best upgrade I've ever done, to anything. (and I upgrade EVERYTHING!!)
I think the Econ tune is more different shift points than anything, I know it shifts to OD and locks up pretty quick. They told me it's closer to 100hp, btw.
The only thing I don't like is how loud it is in any but the stock tunes. It's enough that I use stock, otherwise I never would, aside from warmup.
on
I've had my tuner ( see below for tunes) for a month now..as well as my 5" strait stove pipe..I still don't listen to the radio..and my window is always down and heat on full blast..jacket zipped up tight and kids crying close the window...its been in the 20's and 30's here..the stock tune is just that..stock...the 40 and 60 tow you can feel a power change and the shift points are all moved so you can tow a little better at the right RPM's and speed. it wont shift to second till about 20 to 25 mph with light throutlle.then 3rd till about 35 to 40 mph..there is more line pressure for a more stronger shift with less slipping..mine is backed with a BTS VB..I like to cruse with the 60 tow..it holds in 1st or second gear while going light to light in town and you can hear that turbo whistle very nice there..the 80 econo is awesome..when I hold the throttle at 50 in the stock setting then switch to the 80 econo.my trucks jumps forward and gains about 10 miles an hour.. floor it and hold on..I get smoke from the 80 but very little unless I go full throttle then smoke clears till you let back off or level out....shifting points seem to be closer and still shifts faster with a lot less slipping..over drive holds a lot better too.its a very fun setting..you can feel a seat of the pants power no matter what speed you are going..I use that one a lot too..the 120 setting??well you got to try it.that setting is crazy from a dead stop hold it to the floor the shifts are strong and very fast..you see 100 mph very quickly..lots a smoke behind you as well..but with a stock trany you got to be careful cause it is hard on a trany..you can hear it screaming for help..I live right at the bottom of a mountain here..from a dead stop in stock I barely see 55 mph getting to the top.its a little over 1/4 mile strait up..in the 80 econo I hit the top at 93 mph and still climbing but it go's down hill then a sharp turn after you get up there so I half to let up..I push about 25 to 28 lbs of boost and the egt's climb to 1200 and holds..the lower the setting the slower the egt's climb..but I can push 25 to 28 lbs of boost in any setting except for the stock setting them I'm lucky to get 23 to 24 lbs..my trans has never gone over 125..like i said its been in the 20's and 30's too..but I still haven't installed my true cool ether.. this tuner cost me $450 delivered. it is by far the best $$$ I've ever spent..jody does one hell of a job...
p.s as far as mpg well i cant keep my foot out of it to find out how much better it is..but with all the playing i have been doing im still getting 15 to 16 mpg..in stock i was getting 17..this is around town driving..i also use bio...
Pocket beat me to it. I just got the 80hp tune and have only gone through one tank so far with it. However, I am usually at ~385 miles with 1/4 tank left when I stop to fill up. Right now I am still just above 1/4 tank and have 450 on the trip. Not only that, it has been driven a little harder than normal with the thrills of the new tune. Friends "testing" it cant help but get a little out of control.
I know i need to run a few more tank through to get a little better average, but I can already see the difference and FEEL IT TOO.
Gauges are needed! EGTs climb faster with anything over stock.
You will never be sorry if you get the stuff from Jody.
I would have to say my results are about the same as the other, the lower hp setting I nice towing. Other day had 12000 on the back and my truck would not accelerate going uphill, Switched the hp to 40 and started accelerating. There is a noticable difference than stock. It does have are hard time finding idle when real cold, turn back to stock and no problems. Noticed no difference in trans temps. When I towed 16000 down the interstate, stock to 40-80hp was about a 150 degree higher exhaust temp.
I have stock 40, 60, 80, 100, 1200 rpm high idle. High idle is nice in winter, 100 will puff some smoke and will clear in the upper rpm range. 80 will blow just a little, 60 will blow some when its shift loaded with 8000lbs or more. I usually run in 80 with 1-1.5 mpg better than stock.
Stock is nice to have when pulling in loose ground and ice since rear wheels are not as likely to slip. Alot more injector noise off stock setting.
Dose anyone with the DP tuner also run a 10k mod...i am thinking of starting with it just for fun, or should i just hold out and save up for a DP? the down side is it well take a lot longer to get the wife to let me spend the money on the DP, the 10k is already ok.
___________
1999 F350 PS CC LB SRW 6spd (stock)
First gauges...then the fun stuff
___________
on
___________
___________
More than likely you won't see any benefit from running a 10K mod with a DP-Tuner. Jody's tunes already call for a higher ICP pressure. The 10K mod fools the ECM into thinking that the pressure is too low. So if you are running a chip calling for higher pressures, and you are fooling that chip with too low of a pressure reading, then it's really going out of the intended programming parameters of the chip.
on
Originally Posted by strokin_it7.3
Man, this thread is going to make me so mad... in anticipation. Ron everything you said is basically what i want that my chip now doesn't give me, so i guess i will fall in love with this chip. I'm going all out for 10 positions, so that is why its taking me so long.
