Locking/Unlocking Hubs
Old 11-05-2006, 08:58 AM
TurboTuff's Avatar
TurboTuff
TurboTuff is offline
Hello again
Can someone post the proper procedure for LOCKING and UNLOCKING the HUBS.
Usually I first put the truck in 4X4 then go out and LOCK the HUBS.
Then to take it out of 4X4 I first go out and UNLOCK the HUBS then back in the cab to shift to 2-wheel drive.
Also can I drive with the HUBS locked and the vehicle in 2-wheel drive and just shift between 4X4 and 2-wheel when needed?
TurboTuff
Old 11-05-2006, 09:33 AM
yamaguy's Avatar
yamaguy
yamaguy is offline
Smile
The way i've always done it was to lock the hubs first. I usually do it before I even get in the truck to leave if I think that I might need four wheel drive. That way I don't have to get out into the mud, snow, what have you. When you need it you just pull the lever back into 4-high either at a stop or depending on the year of your truck then your rolling but not acceltrating then just let'er eat!
It's okay to have the hubs locked up in 2-wheel drive. I do it 1 day a month to let the gear lube coat everything well. I have drove with them locked for a couple of tanks of fuel to see what kinda mpg I would lose and I can't even tell maybe 1 mpg. I have also found it to be helpful to use 2-wheel drive low range when moving heavy trailers and dragging things around on pavement or in hilly areas. Why use the skinny pedal when you have gears!
Old 11-05-2006, 10:05 AM
TurboTuff's Avatar
TurboTuff
Thanks yamaguy
Greatly appreciated!
I wondered about driving around with the HUBS locked
Not any more
TurboTuff
EndorphinJunky
Ford Truck Parts for Sale
424
03-23-2015 05:15 PM
Y2KW57
79
02-12-2015 11:47 PM
DasCheckers
11-23-2011 11:34 PM
Martinoman
Arkansas Chapter
02-23-2011 06:16 PM
johnnybecool
1999 to 2016 Super Duty
03-04-2007 12:51 PM
Quick Reply: Locking/Unlocking Hubs
