1990 f150 no power to coil
Old 08-30-2006, 01:30 PM
eric88gt's Avatar
eric88gt
eric88gt is offline
Exclamation 1990 f150 no power to coil
Hello, i'm having a problem with my truck. The other day i went to start it for a kid who's going to buy it, and the truck started, ran for about 15 or 20 seconds, then died like somebody shut it off. It has a new tfi in it, i checked power to the coil, and found none. So i replaced the ignition switch, because i was told that's what it was, but that wasn't it. When i put power to the coil the truck starts and runs perfect. Any ideas as to what would cause this? Any help is appreciated, thanks...
Old 08-30-2006, 04:29 PM
subford's Avatar
subford
subford is offline
I think I would look very close at the Ignition Coil Connector. The same wire that powers the coil also turns on the EEC power relay and if the power relay is not made the engine will not run. But when you put power on the coil you could be back feeding the power relay and ignition module.
Does anything happen when you turn on the key? (radio, gauges, ...)
Old 08-30-2006, 10:07 PM
eric88gt's Avatar
eric88gt
eric88gt is offline
Yes, when you turn the key forward, everything works as normal, the only thing that doesn't seem to have power is the coil.
Old 11-01-2006, 04:02 PM
8996EBBroncos's Avatar
8996EBBroncos
8996EBBroncos is offline
BUMP
I got the same problem with my 89
JayzDaddy
02-04-2015 09:02 PM
rdweathers
17
02-27-2012 09:47 PM
Brad Brown
Electrical Systems/Wiring
01-04-2012 11:36 PM
slafronza
1997 - 2003 F150
29
03-14-2010 09:55 PM
crewcab 350
04-05-2005 01:33 PM
Quick Reply: 1990 f150 no power to coil
