Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 10-31-2006, 01:11 PM
bassproguy07 bassproguy07 is offline
Garage is empty, add now
bassproguy07 is starting off with a positive reputation.
Low Sulfer Diesel
Ok, I was filling up the other day and there was a sticker on the pump that said contains ultra low sulfer diesel. Under that it said Something about It is a violation of federal law to use ultra low sulfer diesel in 2007 or newer diesel engines. Everywhere around here i have seen only low sulfer diesel, and am wondering what are the owners of the new trucks supposed to do? Is there going to be a nationwide switch in diesel fuel? or are these new engine owners SOL?
__________________
1983 F-250, 6.9 XLT REAL P.O.S!
  #2 (permalink)
Old 10-31-2006, 04:51 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
Quote:
I think you misread the sticker. I believe it says it is against the law to use anything but ULSD in 2007 and newer vehicles
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 10-31-2006, 06:29 PM
crosbo's Avatar
crosbo crosbo is offline
crosbo is starting off with a positive reputation.
I don't know Phydeaux, I think I'm with Bass...I think it says that the ULSD that is currently being distributed all most if not all Valero stations, says that it cannot be used in '07 or newer rigs.
__________________
__________________
Tom
'00 CC F250 4x4 Auto 4" Magnaflow, S&B Cold Air Intake, AIH, Edge A2/Juice, HPX, Pre-pump, In-Tank, CCK, 203 Thermostat, Air Horns, XM Satellite Radio, 2" lift, 315's, Trucool 4739, '06 Grill and emblem upgrades, RealTree skins and a hot babe in the passenger seat!
  #4 (permalink)
Old 10-31-2006, 06:53 PM
Phydeaux88's Avatar
I will have to read it again
__________________
  #5 (permalink)
Old 11-01-2006, 10:58 AM
Its says it may not be used in 07 or newer engines because it can cause damage to the engine....
__________________
  #6 (permalink)
Old 11-01-2006, 12:40 PM
FARM69's Avatar
FARM69 FARM69 is offline
FARM69 is gaining momentum as a positive member of FTE.
Guys, if you have a 07 or newer righ you have to use ULSD. Those stickers are confusing. It pretty much states that ULSD may cause engine damage if used in older engines.
Thus, the LSD sticker is just the opposite. It may have 07 and newer engines.
Low suflur is being phased out.. in a couple months or two ULSD will be everywhere.
__________________
97' F250HD 4x4 Intercooled Powerstroke 5 Speed LB / Stage II (180cc) Injectors / HX50 Turbo (19cm) / DP-TUNER / Electric Fuel / Val Air Ceramic
A-Pillar AutoMeter Cobalts [Boost, Pyro, Water/Oil Temp]
4" Straight / 6637 / CCV / 203 Stat
  #7 (permalink)
Old 11-01-2006, 12:58 PM
ok, I'll have to look at the stickers again. If ULSD is going to damage the older engines like my 6.9, what kind of damage are we talking about here? I'm hoping to get one of the newer trucks when the 6.4 comes out unless I find a 1995-2002 model dodge cummins for cheap. but I love the look of my 83 and I would like to keep it in the family for a long time, so if this ULSD hurts my engine I'd like to know what kind of HURT it gonna do
__________________
  #8 (permalink)
Old 11-01-2006, 01:43 PM
DAN-D-DIESEL97 DAN-D-DIESEL97 is offline
DAN-D-DIESEL97 is starting off with a positive reputation.
Where I Fill Up The Sticker Says You Cant Use The Current Fuel In 2007 And Later Engines As It Will Cause Damage.
  #9 (permalink)
Old 11-01-2006, 03:22 PM
crosbo's Avatar
I apologize Phydeaux...I stand corrected.
The LSD stickers I've seen at most if not all Valero stations around here say:
LOW SULFUR HIGHWAY DIESEL FUEL (500ppm Sulfur Maximum), WARNING, Federal law prohibits use in model year 2007 and later highway vehicles and engines. Its use may damage these vehicles and engines.
While the ULSD stickers I've seen at the Shell stations say:
ULTRA LOW-SULFUR DIESEL FUEL (15-PPM Sulfur Maximum) Required for use in all model 2007 and later highway diesel vehicles and engines. Recommended for use in all diesel vehicles and engines.
Either way, I'll continue to add KLEEN to my tank everytime I fuel up...as I do even when I fuel up with B10 or B20 Bio...if not for the increased lubrication, then for the additional cetane kick!
I'd post the pictures of the stickers I took on my lunch break, but I don't know how to post pictures to the forum yet.
__________________
__________________
Tom
  #10 (permalink)
Old 11-01-2006, 04:19 PM
FARM69's Avatar
Bio and Diesel Kleen is the solution to this problem. Mainly Bio because it has awsome lubrication abilities.
Some people have been saying that ULSD has eaten a few o rings throughout the fuel system. I'm unsure if this is true or not but it does make sense.
__________________
  #11 (permalink)
Old 11-01-2006, 04:37 PM
crosbo's Avatar
With respect to the o-rings...my unit was working fine, then I latched on to about 3-4, maybe 5-6 tanks full of low-priced diesel at the Shell station...which just so happened to be the ULSD.
All of a sudden, my drain was leaking diesel like a siv. I tried the open-close attempt a couple of times, still no use. So I ordered the new o-ring kit, let my baby sit for 4 days, then installed the new rings...and all is fine. However, I haven't returned to the ULSD station, and surprisingly, the o-rings that I removed looked every bit as in good a shape as the new one's I installed.
Oh well. Right now I'm running B20, with 15 extra gallons sitting in the garage, in case I run low before heading back up towards Austin where I can pick up more.
Sulfur a problem, yeah whatever. Want to talk about problems...try driving behind any carburated car that is still on the road, particulary an older vehicle that hasn't received much love...now there's the problem!
__________________
__________________
Tom
  #12 (permalink)
Old 11-01-2006, 04:46 PM
Phydeaux88's Avatar
crosbo seems like a case of sticker saturation to me
__________________
  #13 (permalink)
Old 11-01-2006, 04:52 PM
crosbo's Avatar
Could by Phydeaux...could be.
__________________
__________________
Tom
  #14 (permalink)
Old 11-02-2006, 10:51 AM
Ok the Valero now only carries ULSD i looked this morning when i filled up and there was the sticker " Contains Ultra Low-Sulfur Diesel, required for all engines 2007 or newer. Reccomended for all diesel engines." so i guess im runnin ULSD now lol u say it damages o rings? god I hope so, need an excuse to get new Viton fuel lines so i can start runin BIO
__________________
Tags
buy, diesel, fuel, katy, low, tx, ultra
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
