How many lubrication points are on the truck and where are they?
I have a grease gun and i would like to make sure everything is in check, i have a suspicion that my oil change place is not doing the lube even though they say it's included.
Right. There are no grease fittings on it from the factory.
If you install parts with grease fittings just remember that they only last if you grease them regularly. They usually aren't sealed as well as non greaseable parts so they rely on you greasing them to force any water and dirt out.
