1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Lubrication Points????
Old 10-26-2006, 10:53 AM
PAPPYBALL's Avatar
PAPPYBALL
PAPPYBALL is offline
I have an 03' XLT.
How many lubrication points are on the truck and where are they?
I have a grease gun and i would like to make sure everything is in check, i have a suspicion that my oil change place is not doing the lube even though they say it's included.
Old 10-26-2006, 11:50 AM
Ibarria's Avatar
Ibarria
Ibarria is offline
I;ve been wondering the same thing, but, I have been told that everything is sealed..
who knows..??
Old 10-27-2006, 02:02 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
Red face Sealed for life!!
When the ball joints and tie rod ends wear out, replace them with Moog parts, which have grease fittings.
Old 10-29-2006, 10:34 AM
PAPPYBALL's Avatar
PAPPYBALL
So the factory vehicle has no lubrication points????
Old 10-29-2006, 11:27 AM
Racerguy's Avatar
Racerguy
Racerguy is offline
Right. There are no grease fittings on it from the factory.
If you install parts with grease fittings just remember that they only last if you grease them regularly. They usually aren't sealed as well as non greaseable parts so they rely on you greasing them to force any water and dirt out.
Old 10-29-2006, 03:11 PM
Gevans17's Avatar
Gevans17
Gevans17 is offline
no grease fittings
The only one I found is on the steering mechanism...pittman arm I think
Old 10-29-2006, 08:16 PM
Racerguy's Avatar
Racerguy
Racerguy is offline
An 03 Expedition shouldn't have any grease fittings from the factory. 2002 and earlier have 2 on the idler arm.
Dirtbag
05-21-2017 06:46 PM
jaysnyder
Washington Chapter
04-12-2017 07:39 PM
KubotaOrange76
2017+ Super Duty
03-06-2017 06:31 AM
slc10844
2011 to 2019 Explorer
09-16-2012 11:03 PM
mjunk1
1997 - 2003 F150
06-01-2009 04:20 PM
Quick Reply: Lubrication Points????
