96 PSD Vibration
on
when you say you drove it with the driveline out i am guessing you drove it with the rear driveshaft out but in 4 wheel drive? if you still had the vibration with only the front working your looking at front drive shaft, front axle shaft, or tire balance issues. i wouldn't worry about the rear drive shaft at this point.
if this truck is 4 wheel drive. while in 2wd make sure the hubs are unlocked if they are manuals. and drive. if the vib still there. if it is then we are looking at tires more than likely, maybe some weird tran, t-case or diff problem but not likely.
if while driving in 2wd with hubs unlocked the vib is not there then you need to be looking at front drive shaft u-joint as well as front axle u-joints.
tilopa
09-26-2013 05:15 PM
