wstevens
wstevens
I have a 1998 Mercury Mountaineer with a 5.0L V-8, that the check engine light continues to come on despite the truck driving with no apparent problems. I had the check engine light diagnosed and it came up P1400 which I was told it was something to do with "manufactured control auxillary emission control". Can anyone tell me what I need to do to clear up this issue so I can have my truck inspected?
what this is differential pressure feedback egr. (dpfe) it works with the pcmpowertrian control module. it is also know as the backpressure transducer, other words it controls the input pressure to the engine and the exhuast input pressures.
1. disconnect the neg batt cable
2. detach and label the wiring harness connector from the PFE/DPFE sensor.
3. disconnect all hoses from sensor.
4. remove the mounting nuts, then seprate the sensor from the mounting bracket.
5. if necessary, to remove the evr solenoid and the PFE/DPFE mounting bracket from upperintake manifold.
install in the reverse order.
mfp4073
1983 - 2012 Ranger & B-Series
05-07-2015 10:25 PM
fishon2
1997-2006 Expedition & Navigator
07-08-2009 07:08 AM
largefries
19
06-03-2009 05:19 PM
