1997 F-150 odometer problems
I have a 93 T-Bird that just quit working as well only thing is it was at 162000mi, speedo still works fine though! Here is what I found about the Bird's problem online, may be similar.
http://www.mn12performance.com/mn12p...0-install.html
I'm in the process of trying to find a fix for it that is reasonably priced, so far the cheapest I have found is in the neighborhood of $60 (different site from the one above), and that's just for the two small gears. If I were to pull out the cluster and send it in they charge $195. Seems there are quite a few models such as Audi, BMW, etc. that have the same problem.
I get the impression it's another supplier problem! Ford needs to get on the stick with these suppliers of theirs.
This should help you fix the problem. Good luck!
https://www.ford-trucks.com/forums/1...blank+odometer
Noval334
06-26-2019 04:39 AM
Phil Mark Davis
09-06-2006 07:26 AM
