It's a 8.8 rear on a 1994 F-150
Somobody, anybody know the torque on the pinion nut and the socket size. I just change the u-joins and still do that loud knock whe I put it on gear; So I'm going to try tightering the pinion nut to see if I can get away with it.
it can actually take about 350 -400 ftlbs of torque on that pinion nut with new crush sleeve, you better be able to have the truck up on the lift to get the clearance to put a mother of a torque wrench on that pinion nut.
