Biodiesel Cold Start Trouble
Old 10-10-2006, 04:16 PM
Winsted Organics's Avatar
Winsted Organics
Winsted Organics is offline
been running b99 for the summer no trouble. This am 32 degrees and no start. Pulled fuel filter added regular diesel purged air from the system and put 10 gal of regular diesel from the bobcat into the tank to make a 50 50 blend. I've cranked it enough times to get some white smoke out of the tail pipe but it wont stay running. Feathered the gas pump to keep it running for about 1 minute. I've had it plugged in for 6 hours now and the fuel feels warm in the filter. Have I drained the batteries to the point where the crank speed just isn't enough? or is there a chance I burned out the fuel pump with the more viscous fuel?
Old 10-10-2006, 06:00 PM
cookie88's Avatar
cookie88
cookie88 is offline
The pump is pretty robust, I wouldn't replace it just yet. Have you tried jumping it yet? The Super duty is very dependant on strong batteries both for starting and for the glowplugs.
Old 10-10-2006, 06:02 PM
Winsted Organics
Just got back from jumping it. Spun faster, but still nothing. Any chance the engine is full of cold fuel? I saw that on some other threads. If so any way to purge it. It was catching at times with a pronounced knock, but now it just cranks
Old 10-10-2006, 08:03 PM
adambomb's Avatar
adambomb
adambomb is offline
Have you got it started yet? I doesn't get that cold where i live so i havent run into any problems with running BIO. Just to let you know the cloud point for B100 is 32 deg F.
Old 10-10-2006, 09:49 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
Not always, it depends on the oil it was made from. The animal fat bio I've been working with gells at 45 deg, the mostly canola oil I'm using gells at 26 deg. The soy oil I've processed gelled at about 32-33 deg.
FABMANDELUX.
Old 10-10-2006, 09:53 PM
fabmandelux
The lines to your Injectors are full of gelled fuel, If you cannot put it in a heated garage you'll have to blow out the lines with compressed air.
FABMANDELUX.
Old 10-10-2006, 10:11 PM
Winsted Organics
purge fuel lines?
Got new batteries so the crank is real strong. The biodiesel is from Twin Cities Biodiesel. Have not had a problem in two years, but I tend to switch end of September to regular fuel in MN. How does one purge the fuel lines
Old 10-11-2006, 01:30 PM
Winsted Organics
Moral if this repair is keep it simple. Why did it stop? Too cold. Cranked the heater in the shop up all the way. The ford outside temp guage read 100! Sat in there for 5 hours. Went out and it started like nothing was wrong. Done with Biodiesel for the season in Minnesota. Thanks everyone
Old 10-11-2006, 08:43 PM
cookie88's Avatar
cookie88
cookie88 is offline
The one time my truck froze up I would have killed for a heated garage. Glad you got it up and running again.
fordfish
6.4L Power Stroke Diesel
05-09-2014 11:24 PM
jefftb
16
02-14-2014 08:44 PM
privateer, eh
20
01-28-2014 06:11 PM
Webasto 9.1KW
35
02-18-2013 10:38 AM
85GEARHEAD
11-25-2007 06:51 PM
Quick Reply: Biodiesel Cold Start Trouble
