cleaning the beast
I just bought a new pressure washer. Would it be a good idea to hose down the bottom/frame and spray it with rubber undercoating? When I had caliper problems a while back I noticed that the frame was starting to rust, would that rubberized spray take care of it? I have about 4 cans left over from when I restored my horsetrailer. Seems to be holding up nicely. Any thoughts?
-Dave
-Dave
for a frame you should something like zero rust, por 15, or rust bullet. i just used zero rust on my frame and it looks asome. i would use something that you brush on because you can put it on alot thicker that spraying it. all i did was remove the bed wire wheel the framepower wash degrease and than paint. i have heard bad things about rubberized undercoating i am not sure if it is true because i have never used it i chose the zero rust over it.
Undercoating tends to dry out and loosen from the surface it is supposed to protect.
Once it loosens, it traps dirt and moisture against the metal.
The more dirt you have trapped, the more moisture you will have trapped as well.
Moisture and steel are not good things to have trapped together.
I would use Rustoleum paint before I used undercoating.
Brush application does give much better coverage than spraying.
Por 15 or Rust Bullet I have read about and both look like very good products, expensive but good. I have never read about Zero Rust, but it must be on the same lines.
Originally Posted by CheaperJeeper
I like Hammerite. It is about 1/2 to 2/3 the price of what you're paying for Zero Rust.
PLUS it gives that "hammered metal" textured finish (great for hiding imperfections), it can be painted right over rust, and it will neutralize whatever rust is already there...
Originally Posted by Dave7.3
Where can you find Hammerite and what does it cost? Is it available at any auto parts store?
It also comes in smooth finish, and spray cans.
i have never heard of hammerite i will have to try it on my next project i like that its only $10 a quart. i was going too use por on my frame but then i seen the price of it and i just couldnt bring myself to spending $45 on a can of paint no matter how good it is so thats why i chose zero rust too bad i didnt know about this stuff thanks cheeper.
You're welcome BrownieBoy525.
I use it on ALL my fab work projects. It goes on thick and the dimpled finish does great at covering grinder marks and such. It takes a week or so to fully cure - though it dries hard enough to touch in just a couple of hours. When fully cured it is "glass-hard" (their description), very shiny and quite tough.
You do need to be aware that the hammered finish "black" isn't really black though - more of a dark charcoal gray. The smooth finish stuff is pretty much true black though.
Try it, I think you'l like it.../
Hi,
i have many experience with hammerit, but they are bad.
Yes, hammerit is cheap, but when you want prepaire your car for years, you must buy many more hammerit later.
I work with 4x4 cars and trucks, we prepaire them for the Sahara, Rally events or for work in forrest, sierras, snow...
The hammerit is ok for 1 year, no more. flying stones an fast flying insects bring more and more holes in the paint, and the rust is working under the paint.
Now we only work with Por15, and our customers and myself are very lucky, because this material is good for a long time and ok under all bad conditions.
Por15 is a real hard stuff, stops the rust, it will be harter and harter with air moisture, no scratches or bubbles.
Josh
Josh
Originally Posted by LaPuente
Hi,
Josh
Josh
One of the nice things about Hammerite is that, since you can paint right over rust, any rock chips that do start to rust are very easy to fix - just paint another coat right over them. Like I said, I've had nothing but good experience with it, and I have stuff I painted with it YEARS ago that is still looking good.
Were you using the brush-on or the spray cans?
Hi CheaperJeeper,
i used hammerite with different methods, pistol, brush, spray and rollers.
I dont no why our expierences ar so different...
i know some people with good experiences with hammerite, and many people with bad experience.
This with the insects is real.
We have big and hart flying insekts, i don't now the name in english, when they crashed on the bumper and you take it off, a good many times you lost a slip of the hammerite paint.
For example my Discovery, with the same bumper, but painted with only one layer of Por15, i have no problems in this.
Or the chassis, flying stones make lost the hammerite, so i clean the hassis completly from the hammerite, paint it with Por15, only one layer, and it's like new since 2 years.
My experience with hammerite is, it's real ok for static metal things in the garden like chairs and so, but my image is, it's not god for vehicles by reason of vibrations and many movements.
Josh
Josh
So, pressure wash the underneath of the truck, degrease, grind any bad spots on the frame and then hit it with one of the three products (hammerrite, POR, 0 Rust) and then paint??
This may be a dumb question, but I'll ask anyway -- since the body is on the frame with all the parts, pieces, lines, etc.......do I just cover it all with one of the three products doing the best I can??
