Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 09-18-2006, 12:33 PM
4tune81 4tune81 is offline
Garage is empty, add now
4tune81 is starting off with a positive reputation.
trouble getting flat8 started
I have a 41 flat8 and left the key on for a few days...recharged the battery now no fire...cranks fine and powerfully but no spark...new to flatties and not sure if I burnt something...points? coil? what do I look for?
  #2 (permalink)
Old 09-18-2006, 03:03 PM
HOTRODSURFER HOTRODSURFER is offline
HOTRODSURFER is starting off with a positive reputation.
Probally Burndt Up The Points,try Replacing Them First!!
  #3 (permalink)
Old 09-24-2006, 01:43 PM
John2Thomas John2Thomas is offline
John2Thomas is starting off with a positive reputation.
Most likely the points are welded closed, it's an easy fix.
  #4 (permalink)
Old 01-10-2007, 08:32 PM
Scortchin' 41 Scortchin' 41 is offline
Scortchin' 41 is starting off with a positive reputation.
i'm havin the same problem! gonna check that out first thing tomorrow, after i get home from work!
thanks guys!
  #5 (permalink)
Old 02-24-2007, 12:48 PM
F6Guy F6Guy is offline
F6Guy is starting off with a positive reputation.
pull the cap and have someone spin the motor for you and see whats going on. I had the same problem and the ground wire in the distributer had a bad connection.
  #6 (permalink)
Old 03-01-2007, 12:45 AM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
Check the wire from the points that goes to that stud throught the side of the housing. Mine had a plastic washer to keep the primary wire from grounding out, it had cracked from age and grounded out.
__________________
Rod 51 F1 Truck
Flathead 6 / 3.23 Rear
S-10 5-Speed
"Keep on Truckin"
  #7 (permalink)
Old 07-20-2007, 09:15 PM
hey. dad and i opened the distributor and sprayed some electric cleaner in it. closed her up... and now she fires instantly on the first crank!!!
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
