trouble getting flat8 started
Old Sep 18, 2006 | 12:33 PM
4tune81's Avatar
4tune81
I have a 41 flat8 and left the key on for a few days...recharged the battery now no fire...cranks fine and powerfully but no spark...new to flatties and not sure if I burnt something...points? coil? what do I look for?
Old Sep 18, 2006 | 03:03 PM
HOTRODSURFER's Avatar
HOTRODSURFER
Probally Burndt Up The Points,try Replacing Them First!!
Old Sep 24, 2006 | 01:43 PM
John2Thomas's Avatar
John2Thomas
Most likely the points are welded closed, it's an easy fix.
Old Jan 10, 2007 | 08:32 PM
Scortchin' 41's Avatar
Scortchin' 41
i'm havin the same problem! gonna check that out first thing tomorrow, after i get home from work!
thanks guys!
Old Feb 24, 2007 | 12:48 PM
F6Guy's Avatar
F6Guy
pull the cap and have someone spin the motor for you and see whats going on. I had the same problem and the ground wire in the distributer had a bad connection.
Old Mar 1, 2007 | 12:45 AM
51ford fan's Avatar
51ford fan
Check the wire from the points that goes to that stud throught the side of the housing. Mine had a plastic washer to keep the primary wire from grounding out, it had cracked from age and grounded out.
Old Jul 20, 2007 | 09:15 PM
Scortchin' 41
hey. dad and i opened the distributor and sprayed some electric cleaner in it. closed her up... and now she fires instantly on the first crank!!!
classicrat52
May 8, 2015 07:30 AM
newold46
1947 and Older Ford Trucks
Mar 18, 2015 09:31 PM
Pappys53
Apr 25, 2014 04:16 PM
BigCrzyRdNeck
Flathead V8 & Flathead 6
Dec 7, 2005 12:14 AM
blsd49
Oct 22, 2005 09:02 PM
