Finding the spout
Finding the spout
It says in the Haynes book "trucks with the double spout connector incorporate a special shorting bar remove shorting bar? I believe the two red wire plug end with the grey square cap is the spout, it is by the ecm. Question is do I remove that grey cap? Is that the shorting bar?
The SPOUT connector will be near the TFI ignition module. On older trucks they were mounted on the distributor; on 92-up trucks they were mounted on the drivers side fender. If you are unsure of what you have found, pull it, and verify with the timing light that the timing doesn't change when you rev the engine.
javi2001
13
06-18-2005 04:55 PM
Boldt
19
01-08-2003 11:51 AM
