What caused the DPFE sensor to melt?
Old 08-29-2006, 12:02 PM
tmm66's Avatar
tmm66
tmm66 is offline
I have a '99 EX with the 6 cyl OHV motor. I found the HIGH port on the dpfe sensor was melted and the hose that connected to it was severely cracked. I replaced the sensor and hose but would like to know the root cause of the problem. Any suggestions?
Old 08-30-2006, 08:08 AM
renchr56's Avatar
renchr56
renchr56 is offline
The exhaust tube may be plugged with carbon. you will have to pull it & find out.
Old 08-31-2006, 11:56 AM
tmm66's Avatar
tmm66
tmm66 is offline
I'll try it hopefully this weekend. If this tube was clogged, wouldn't this cause the "check engine" light to come on? Just wondering...
Old 08-31-2006, 12:39 PM
renchr56's Avatar
renchr56
renchr56 is offline
depends on if it is clogged all the way or not
Old 09-05-2006, 01:56 PM
tmm66's Avatar
tmm66
tmm66 is offline
The tube was not clogged at all. The hose from the HIGH port did show signs of carbon buildup. We'll keep an eye on it.
thanks,
Old 09-06-2006, 11:31 AM
BowTieHatr's Avatar
BowTieHatr
BowTieHatr is offline
the sensor it self shorts out and over heats. seen a few of these. atleast you did not have to replace your intake
Old 08-12-2012, 02:42 PM
George M Baxter's Avatar
George M Baxter
George M Baxter is offline
Sorry your all wrong!
In normal operation there is no gasses traveling through the tubes. This device measures deferential of pressure. But as you stated the hose had cracks (leaks) This aloud the hot gasses from the Exhaust to flow through the hose to the DPFE sensor melting it. A clogged line would not melt the sensor but would make it inoperable.
Old 08-12-2012, 03:05 PM
George M Baxter
More info
Witten by wildbill a person that worked for the company that designed and manufactured the sensor for Ford Motor Corporation.
Exhaust stream does not pass through this transducer(DPFE) the pressure applied to the sensor is a dead head so the thermal transfer is contained to the stagnant air trapped in the hoses to the sensor that is very slow to transfer heat.
The plastic housing was to reduce cost of this transducer(DPFE) not to dissipate heat in fact the plastic transducer would melt with pressure leaks.
jetfiremuck
Aerostar
12-17-2016 11:28 PM
jetfiremuck
Aerostar
12-07-2016 08:41 PM
carlakally
New Member Introductions
04-23-2013 03:19 PM
piedmont
08-16-2007 10:07 AM
hgillesp
1983 - 2012 Ranger & B-Series
07-29-2004 10:02 AM
Quick Reply: What caused the DPFE sensor to melt?
