I just went through and replaced all injectors orings and checked all the wires.I still have a miss at 1100 rpms. It seams to go away at idle and at high rpm. The scanner does not pick up any problems with the contribution test.All injectors are working. I also cannot get my boost above 15 psi. map hose is good. Any ideas???
