Poor mileage, Interesting cause?
Originally Posted by Flea
I have 96K on my '97. I don't know how long it has been since the tranny fluid has been changed. It smells okay at best. But it isn't slipping.
Should I drain it. Some of it or all of it?
Thanks,
Fletch
Thanks,
Fletch
Drop the pan and drain the converter, blow out the cooler lines, better yet flush the cooler. Replace the filter and refill with the same amount of fluid you removed.
Flea, Not sutre what you mean, but draining all the fluid won't hurt your tranny. Put in about 10-12 quarts, fire it up, shift into forward, reverse, then shut it off. Add the remaining amount. Run it till it's good and hot then check the level. I run mine a tad low cuz overfull is bad for the tranny.
Make sure everything is clean, pan, magnet, cooler ect. ect.
Drain the tranny and the torque converter. there is a drain bolt in the torque converter, 7/16" i think but its been a while. you will get 6 to 8 qts out of the TC then use full synthetic ATF to refill. To check the TC lockup you will need a scantool that shows a data stream and the status of the TC solonoid. Because I ID's the problem as the brake being constantly applied, I didn't need to checK the TC status as the TC will not work with the brake applied.
My 97 does not have an external tranny cooler. It's plummed into the radiator. It's a GREAT idea to get an external cooler if you tow. I switched to synthetic about 100,000 miles ago and use no external cooler. My temps don't even register on the gauge normally. If it's 90+ out it will hit 170 if alot of idiling. I was caught in hurricane Rita last year. In the truck for 16 hours straight.. Temps were about 180.
ok. I'm a little confused about the brakes. I believe I have a similar problem on my 97.' My electronic brake controller would always stay on leaving me tailights on all the time. I eventually cut the wires to my brake controller. So this BPA which is on the top of the master cylinder could cause that?
skeeter4x4
11-06-2006 05:19 PM
