rear plastic panel removal
Can you be a little more specific as to what panel? that may help someone help you. As for panel removal, most panels always have hiden or hard to see screws. I would take my time and just go one screw at a time, never try to pull of force the panel off. Unfortunately, some panels do require specialized tools. Hope this helps.
What year truck? On my 2003 and 2004 the panel with the ac stuff is a pain to remove. Starting with the upper seatbelt slide bolts and eventually the lower torx seatbelt bolts and two other upper panels and then the whole lower panel. But you might be able to remove the cup holder/pocket on top of the panel and get to the white box.
Good luck,
Chad
Good luck,
Chad
I replaced both actuators on my 03 without removing the side panel, my arms were a bit sore from squeezing in thru the top tray and front cup holder openings. IT took a lot of patience but it can be done. I was able to pry the top tray out and then reach inside and forward to pop the cup holder out. working through both openings I was able to replace the front actuator. most of the work is done blind, by feel only.
Jim
Jim
PATIENCE. The side panel does flex a bit so you can slide you arm in between the side panel and the air handler. My forearms were pretty sore from slideing in thru the top tray but I felt it was worth it versus pulling the side panel. I've had too many of the metal clips tear through the plastic that I wasn't going to remove the panel if I had to. Most of the work is done blind, you can see the actuator once you remove the cup holder.
The temperature controller is down on the side of the air plenum access thru the tray opening. The actuator that controls air flow to the ceiling or side vent is mounted forward with access thru the cup holder.
Deviantsblum
06-12-2017 10:32 AM
shagnwagn
16
02-18-2017 09:04 AM
Big Big Blue
05-04-2016 09:04 PM
