fuel pump pressure
Old 10-31-2004, 12:40 PM
ddalesr3's Avatar
ddalesr3
ddalesr3 is offline
fuel pump pressure
i have a 1966 ford f-850 fire truck with a 401 c.i. engine. the in-tank electric fuel pump has gone bad. it is an after market pump in a tank put on by the fire truck manufacturer not ford. i've taken it to a few auto parts stores and no one has seen anything like it so finding an original replacement is looking impossible. what i need to know is if i purchase an inline fuel pump what psi should i go with? any help is greatly appreciated.
scott
Old 11-01-2004, 06:48 AM
HOTWRENCH's Avatar
HOTWRENCH
HOTWRENCH is offline
Talking Fuel Pump
Scott what you need is a high volume pump at about 5-6 psi. It takes alot of
fuel to run one of these old girls!! We have used carter@ holly rotary pumps with good sucess.
I hope this helps HOTWRENCH
Old 11-01-2004, 08:28 AM
Birken Vogt's Avatar
Birken Vogt
Birken Vogt is offline
Sometimes fire trucks used a return to tank system similar to modern fuel injection to combat vapor lock when pumping stationary for a long period. So the in-tank electric pump may be more of a constant displacement type than a carburetor pressure limited type. What you will have in this case is a pressure fuel line running to the engine, and some sort of bypass valve at or near the carburetor, and then a return line to the tank. In this case you will need a different style of pump.
A caution here. The aftermarket pumps I see in catalogs worry me a bit because they usually specify something about racing applications and I suspect that they might not have the longevity or reliablilty required for an application such as this. There is one company I know of called Facet that makes commercial duty fuel pumps. I think Holley also makes some but they may or may not be good enough for the application.
Birken
Old 11-01-2004, 07:00 PM
ddalesr3's Avatar
ddalesr3
ddalesr3 is offline
thanks for your help guys, i really appreciate it. i double checked the truck and there is not a return line to the gas tank so i don't have to worry about that.
scott
Old 11-01-2004, 07:33 PM
HOTWRENCH's Avatar
HOTWRENCH
Talking Fuel Pump
Scott our garage has serviced Lots of old FORD SD"S the best results were with either CARTER, STEWART WARNER , OR HOLLEY pumps . We have tried
Fawcet pumps with no LUCK!!
Good luck HOTWRENCH
Old 11-01-2004, 10:05 PM
Loan Ranger's Avatar
Loan Ranger
Loan Ranger is offline
The Ford fuel pressure specification for the 1966 401--irregardless of whether it is a 2V or 4V engine--is given as 4.5-6.5 PSI.
Was your electric fuel pump activated by a primer switch on the instrument panel? If so, it should be an auto pulse electric unit. They were used on Ford fire apparatus built by both Autolite and AC Delco.
After being involved with Fords and repair parts for over 30 years, I most surely agree with Hotwrech's post: I have YET to see a SINGLE Fawcett electric fuel pump that was worth installing!
Old 05-05-2020, 03:51 PM
Adam Friday's Avatar
Adam Friday
Adam Friday is offline
Loan Ranger, is this fuel pressure true for a 1968 Ford Firecat, with a 534 engine??
moparpig77
04-25-2017 03:52 PM
hdfe
07-14-2016 02:05 PM
Christopher Layton
01-24-2016 08:50 AM
predaina
29
03-29-2011 07:07 PM
jtttj
1999 to 2016 Super Duty
07-05-2008 09:03 PM
Quick Reply: fuel pump pressure
