Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 05-28-2002, 05:57 PM
Rob00GT Rob00GT is offline
Garage is empty, add now
Rob00GT is starting off with a positive reputation.
Swapping Lincoln Versailles rear into '63 Unibody, got ??
I'm leaning toward the ECI kit to convert my drums to discs on the front. As for the rears, I'm one of the lucky guys that has a Lincoln Versailles rear end laying around. I haven't measured anything yet (overall width, bolt pattern, etc.) and was wondering if anyone has performed this installation?
If so, what parts am I going to need? Has anyone posted a procedure for the swap on the web?
If I go with the ECI kit and the Lincoln rear, what other miscellaneous parts will I need? What type of master cylinder, etc.?
Oh yea, and how do you spell "Versailles" anyway?
  #2 (permalink)
Old 05-28-2002, 06:42 PM
jowilker's Avatar
jowilker jowilker is online now
1966 Ford F-100
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
jowilker jowilker
__________________
In the cool still quiet hours of night, you can hear chevies rusting away.
  #3 (permalink)
Old 05-28-2002, 09:25 PM
Binford Binford is offline
Binford is starting off with a positive reputation.
:-( You might want to check on brake parts for that Versallieses rear end. If my memory is ??? oh well I think HotRod ran a disc brake article once and recommended skipping those because of part unavailibility or something.
__________________
Rick
  #4 (permalink)
Old 05-28-2002, 10:02 PM
matt65f100 matt65f100 is offline
matt65f100 is starting off with a positive reputation.
I put one of those rears in a mustangII. What a mess. To have the brakes actually work depends on the how you have the park brake hooked up.AND calipers and P-brake parts were made of unobtainium. I tossed the whole works.That was 1989,maybe the hotrod aftermarket has a souloution by now.
  #5 (permalink)
Old 05-29-2002, 06:49 AM
hotrodford_88 hotrodford_88 is offline
hotrodford_88 is starting off with a positive reputation.
Rob,
I'd be willing to bet, that the bolt pattern on the Lincoln rear end is a 5x4.25 or 5x4.5, with which you'll have to change your rear wheels.
I'm personally going to look into the kit from Stainless Steel Brakes, for the 9 inch in the Ford Pickups.
I believe the kits run somewhere near $500 or so.
I'll do some checking & get back with you.
Kyle
__________________
1965 F-100, 390, Edelbrock Performer RPM, Holley 600, Pertronix ignition, Edelbrock Performer Cam, K&N Air Filter, Flowmaster 2 chamber mufflers, Heddman Headers, A/C, Lokar transmission mounted shift
Tags
end, lincoln, rear, specs, versailles
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
