Brake Light Switch Stock 6 Volt
Old 08-15-2006, 09:24 PM
5 Star's Avatar
5 Star
5 Star is offline
Does any one have any input on this topic?
A friend of mine was told by another guy that the Halogen Bulbs that are recomended by various parts sources to be used in the Panel Trucks, can burn out your Brake Light Switch.
I recently bought a pair of these 6 Volt Lamps for a friend of mine as his Tail Lights were very dim at night. These were a great addition to his vehicle and work just fine, and now his Ride can be seen by others.
He was recently told by another that they will burn out Brake Light Switches. I myself can't see why, but is it possible?
Old 08-15-2006, 09:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
Unless the halogens are a much higher wattage, I can't see how they would affect the brake light switch or the turn signal switch. Are these halogens made specifically for 6v? Halogens are very voltage sensitive. If the rest of the system is not 100%, especially grounds, they won't last.
Old 08-16-2006, 09:11 AM
5 Star's Avatar
5 Star
5 Star is offline
I got these from Nifty Fifties, and their catalogue, although I don't have it right in front of me to read word for word. States that these are recomended for the Panel Trucks with the metal caseing and glass lens. Not recomended for plastic lens tail lights, because of heat generated, from these lamps.
Also yes they are made for the 6 Volt powered systems. Most of the early Panel trucks that I can remember "Ford", used the same lamp as the 41 Ford car, right on into the fiftys.
I bought these lights for use on a 46-48 Ford car. These lights are basically the same construction as the panel Trucks, with a slightly minor lens and body design, both have the steel body and glass lens.
Old 08-16-2006, 08:14 PM
286merc's Avatar
286merc
286merc is offline
First, turn off the bold type, we aint blind or deaf!
Halogens run higher wattage but that shouldnt bother the old style MS mounted switch as they are plenty beefy internally. At least good ones from Standard are, cant say about cheappo imports.
Flying Monkey
25
12-09-2014 09:46 PM
maples01
11-02-2014 07:24 PM
frogmun's 55
05-15-2007 08:56 AM
53redford
29
05-21-2006 01:30 PM
Third Coast
10-28-2004 01:43 PM
Quick Reply: Brake Light Switch Stock 6 Volt
