78 f250 4X4 2" lift...What shocks?
I have aquired a 1978 F250 4X4 with a D44 front.....it has 2" lift on front....
I have used the search ... found nothing yet..
Can some one tell me a part # for a set of front shocks that are 2" longer than Stock? I can use on this truck.
any brand....or do I have to use shock extenders?
Thank you. J.P.
Wisconsin
Thank you. J.P.
Wisconsin
Hello And thank you...The broncograveyard is great......
would any one know of a 2" longer shock I might be able to get at a local parts store
like a monroe or gaberal or some thing?
or would a Hi boy shock be taller.....and do they have post on both ends?
or would they be to tall?
Thank you again
J.P. Wisconsin
Thank you again
J.P. Wisconsin
If you want to do a little parts book research, you should be able to come up with longer shocks. Just match up the mounting styles and the OE lengths to use as a baseline.
You may also be able to cross the Superlift numbers listed above to a Monroe shock.
The easiest is to order for a 2" lift application from Superlift, Rancho, Doetch Tech and similar that deal with lift applications.
Jason
Jason
Truckie256
1999 to 2016 Super Duty
01-05-2015 11:45 PM
scooter6529
01-31-2011 04:37 PM
88broncII
1983 - 2012 Ranger & B-Series
21
06-25-2006 10:14 AM
